Question about Sony KP-53XBR300 53" Rear Projection Television
Flashing screen I have a Sony KP-53XBR300 53 in. rear projection television. The power light blinks with a pattern of 5 blinks, pause, 5 blinks...... The screen itself flashes on and off repeatedly, and as time goes on, longer and more frequently. We were able to increase the time between screen flashes by adjusting the picture, but we are about as low as it goes. Also, we've noticed that the screen flashing increases with the "intensity" of colors on the screen. For example, cartoons flash more rapidly than regular programining, and football games flash more rapidly when showing actions on the field vs the guys in the booth. Is it time to give it up?
  • vinjlo Mar 01, 2009
    same thing- same model. mine flashes 5x , delays 5 sec, flashes 5x, etc. have sound, no pix
  • Sony Master
  • 8,617 Answers
% blinks for your model means a video output abnormality. which translates into IC7101, IC7201 or IC7301 on C board circuit is faulty or else its transistors Q510, Q516 or Q524 are faulty on the A board. I would check the transistors first for being faulty and if they check out then suspect one of the ICs
Posted on May 12, 2008
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony KP-57XBR 57" rear projection tv screen blinks and timer/standby red light flashed 5 times
Should be loss of vertical output. Could be output IC, loss of drive from A board, or loss of power supply to vertical out IC. Probably need a shop. Not too bad of problem to fix, though.
Apr 17, 2010 | Sony KP-57XBR10 57" Rear Projection...
Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready... Stand by light flashing, TV will not turn on
need to know the number of blinks as thats an error code. it should blink a series of blinks pause briefly then repeat the sequence.
Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
My 5 year old Sony wide screen projection TV (KP-51WS510) stopped working today. All I get now is a blinking red standby light. I accept that I will probably have to pay someone to fix this but can you...
The blinking should be in a repeated pattern of a count, pause,count... Can you post the count please? This is a diagnostic code that will indicate the circuit in which a problem was found. Armed with that info, we can give you an idea of the problem, its solution and the approximate cost.
Thanks,
Dan
Nov 10, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony Rear Projection TV - KP-46WT500 Screen went blank
When Sony TV gets problem it goes to standby as protection mode and LED start flashing.
Do you see standby light blinking?
There would be 3 seconds interval between blinks so count from pause to pause and let me know.
Thanks.
Sep 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
Dec 05, 2008 | Sony KP-57WS520 57" Rear Projection...
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KP-53XBR300 53" Rear Projection Television Logo
326 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
