Rank: Apprentice
Rating: 100%, 1 votes
Some shredders have optical sensors with a dark sensor LED on one side of the slot, and a clear transmitter LED on the other. You will most likely have to disassemble the shredder housing to clean them.
MAKE SURE TO UNPLUG THE UNIT.
Generally you will find screws on the underside of the shredder unit, with one screw covered by a "warranty void if broken" sticker. Remove these screws, separate the housing, and clean the optical sensor pair with windex or isopropyl rubbing alcohol. If your shredder has a CD slot, it may have its own sensor pair. Be sure to clean both pairs of sensors, as the CD sensors seem to be the ones that have the most trouble because of small aluminum debris.
