Question about Microwave Ovens
Door switch is bad on my Whirlpool microwave
How do I go about fixing a bad door switch? From what I've read on this website, it appears as though thagt is my problem. I have a Whirlpool MH1140Xm above the range model and would hate to have to buy a new one if this is something that can be easily fixed on my own or by someone else. Thanks!
  • Microwave Ovens Master
  • 9,098 Answers
Here are lniks you need:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Posted on May 12, 2008
Rmc305pdq2 door error
please use this stpeps and fix it. God bless you
  1. nspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switch If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fuses To determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motor Locate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 22, 2013 | Whirlpool Microwave Ovens
No power
make this test and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 05, 2013 | Whirlpool MH3185XPS Microwave Oven
Microwave has stopped heating, yet grill and convection oven still work.
A model number would have helped, but I can give you a generic answer.
It may be a bad door switch or mount.
(Anybody in the home opening the door while it's cooking?)
See our help file on door switches here.
Mar 01, 2013 | Microwave Ovens
After a brief use, my microwave shut off, said end, and after we removed the item inside, the face of the oven went black. We have tried plugging and unplugging the oven into other outlets, but it still...
I say this a lot on here, but may be bad fuse due to bad connections. The fuse holders these companys use are so cheap they get hot if the unit is run for a long time and the fuse Melts at the end, and goes bad. Possibly something shorted out and blew the fuse, But, it had gotten to the point where it said end so it had completed the cook cycle. So, either over heated fuse, or bad door switch that caused it to blow the fuse.. If another switch goes bad or doesnt act like it should, another one is designed to blow the fuse when the foor is opened as a protection feature.
Oct 06, 2017 | Whirlpool MH1140XM Microwave Oven
While changing the light bulb on the bottom of Whirlpool MH1140XM, the bulb popped. I replaced it but now all I get is a hum whether I push timer, light or oven settings. The oven appears to be heating...
Hello, Thank You for using FixYa. I will be helping you today.Make sure no wires were pinched in the process. The turntable motor runs off the board that's why im thinking you have a grounded wire somewhere.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Whirlpool MH1140XM Microwave Oven
My microwave will not shut properly. The top latch will not completly close. The microwave still runs... but It will not heat food and it makes a clicking noise. Can this be fixed or should I purchase a...
Hi, quite often this is due to a bad door switch located inside behind the area where the door hooks go into the oven.
Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure.
In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide for $32.50, but it's usually a door switch.
It can be fixed......
Apr 28, 2011 | Whirlpool MH2155XP Microwave Oven
I have rust like streaks inside my Whirlpool Microwave Door Panel. It is unsigthly. How do I get rid of the rust-like streaks?
Disassembling the door is a major pain and the streaks will likely only be faded not removed completely. Best solution is replace the door. Otherwise taking it apart(and not damaging it) is your only option.
Eric
May 19, 2010 | Whirlpool MH1140XM Microwave Oven
I have a Whirlpool Microwave that runs when I open the door Model# GT4175SP. Any ideas?
Remove the case and confirm that the door latch switch is mechanically intact. Next, disconnect the switch and test it with an ohm meter to see that it is actually working. It should show a short (0.0 ohms) when the door is closed and no reading when the door is open. Those readings could be reversed but there should be two distinctly different readings when testing the switch. If you don't see any differnce between readings when the door is open or closed then replace the switch. This should solve your problem.
Oct 16, 2009 | Whirlpool GT4175SPS Stainless Steel 1200...
Microwave Ovens Logo
682 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
