Question about Electrolux Central Vacuum
My rather old cannister vac has something clogging the hose. Any ideas on how to clean it out ?
  • 694 Answers
Attach hose to exhaust port of canister. Switch on. That may be enough to blow out the clog. If not, place wand end of hose to intake of vacuum so you have both ends "attached to the vacuum. This should do it. If not, you might try using something with greater suction. Like taking it a nearby carwash and using a vacuum there. Try placing "wand end" of hose to other hose first and turn in. Then the other end.
You can try pushing a long length of PVC or similar pipe through. No jamming. Care needs to be taken when doing this as it may cram the clog tighter,
If the hose is rather old as well, it may be a good idea to simply replace it. It likely has multiple leaks and great loss of suction.
Posted on Sep 05, 2010
How to Unclog Vacuum Hose
you may have to make something out of heavy spring material so you can push it down the hose and be able to manipulate it.simular to what plumbers use.
Aug 14, 2014 | Hoover Vacuums
Loss of suction
If it is running and you have no suction, there has to be a clog in the dirt path. To clear it, start at the head of the vacuum (where the dirt goes in) take apart or disconnect everything you can along this path until you arrive at the bag or cannister. Take pics with your cell phone so you can reassemble it. Hoses: run a broom handle through all hoses to assure they are clear. If you have a shop vac or similar, try applying vacuum to all parts of your disabled vacuum in reverse. Are there filters on your machine? Make sure they are clean. You probably don't have hoses connected, but if you do, check them as I said.
I pick up vacuums along the road all the time. Very few are more than a few months old. All of then have a clog in the hose or elsewhere in the dirt path. I clean the path and sell the vacs for a slightly discounted price. VERY rarely is it a motor problem.
I hope you find this comment helpful. Here they are in under 5 minutes. Thanks for using FixYa.com
Jun 27, 2011 | Kirby G5 Bagged Upright Vacuum
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 | Vacuums
Debris getting stuck in vacuum hose
Check that the filters are completely clean. If there are clogged they would have to be washed and then dried to room temp (or a low temp tumble dryer, put the filters into a pillow case with a towel and install into the machine) Tip the bissell backwards to make sure the bottom bin is pushed and locked all the way in. Only when the two seals meet will you know that the bin has locked in properly. Unhook by prising the main hose at the back off to check for clogs as well as the main hose at the bottom and the main dust channel at the sole plate where the roller bar is. You may have to remove the bottom plate to check for any obstructions behind the brush bar.
I have the Easy vac myself. Its not an Easy machine to maintain when it gets clogged!
Mar 22, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
My central kenmore vacuum wont suction
Hello hdd85,
I think you answered your own question when you verified that all the vacuum outlets have vacuum on them and then after you hook up tyhe vac hose, you fail to get vacuum at the other end. I would say that based on your problem description, you have an obstruction in the hose. You may have afriend with an air compressor that you can try forcing air in one end to free up the clog but if that doesn't work, do you know anyone with a wet/dry utility vac that you can try using the vacuum or exaust side to free the hose up ? Lastly, if you know an electrician, they normally have 'snakes' used to fish wires thru wall cavities... If careful, that might get the clog out.. Hope that gives you soem ideas on how to resolve,,,,
Regards,
Rick
Jan 26, 2009 | Vacuums
Sounds funny/shutting off after few minutes
Yup! Clogged hose on the back of the cannister! Unit is designed to shut off for 30 minutes when this happens to protect your motor. Remove top of hose where debris enters the cannister through a filter above it, then remove the other end of the hose from the bottom of the back of the cannister, take it outside and use something long that'll fit inside the hose to force out all the clogged debris and hair through the top of the hose.
Oct 17, 2008 | Bissell LiftOff Revolution Pet Vac 37602...
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Bissell Lift-Off Turbo power outage
We experienced the same thing. There are several filters on the vacuum cleaner that need to be cleaned out regularly (monthly in the user's guide). But the reason ours was shutting down is a protective circuit that cuts power for 30 minutes to avoid burning up a motor when there is a clog. Our clog was in the hose on the back of the cannister. One end of it can be lifted out of the bottom. The other end locks into place on the top (by rotating the ring on the end of it). It is the path for the hair and debris to the bagless cannister. We found that the top end of that hose was clogged with hair preventing anything from going into the cannister. So if your cannister is not filling, that's probably your problem. Easy to remove the hose and it's only about 18" long, so find something to stick through it and force out all the clogged debris and hair. Good luck!
Nov 13, 2007 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Vacuums Logo
54 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
