Question about Microsoft Xbox 360 Controller
My second controller for my 360 doesnt sinc, the light just flashes HELP!@@@
  • 70 Answers
Look on the top of the controller and press the small round circle, its very small! then on your xbox 360 press the small circle next to where you plug the memory card in and your xbox should find your controller.
Please leave 100% votes, thanks.
Posted on Sep 06, 2010
How I fix the xbox 360 controller blinking and sync light problem,when the sync button doesnt work?
My only guess would be that you disconnected the cable to the sensor while cleaning your Xbox. Have you checked all the connections before reassembling it? Check out the video I linked, maybe it'll help you!
Dec 16, 2014 | Microsoft Xbox 360 White Console
Yes, this can be tricky sometimes.
Be close to your console when synching your controllers. As always make sure the controller is on.
You will need to press both the synch button on the console and on the controller approximately the same time. If you have done this correctly. The controllers should have synched to the console in a few seconds.
Here is a link to show you how to do it for the Xbox 360.
Connect controller to your Xbox 360
To synch a Xbox One Controller go to link below here.
Connect wireless Xbox One controller to your console
Also just in case the light is flashing the and the controller is already synched, that means the battery is low and you need to change it out for new batteries.
Hope this has helped and good luck.
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
When i connect my wired xbox 360 controller into the usb slot of the xbox 360 console, the light on the controller lights up for about a second and then stops working completly. How could i fix this? If...
I can't help you much since i can't physically fiddle with it, but my best guess would be either a damaged USB port or the USB connector on the controller is damaged.
Jan 16, 2011 | Pelikan PELICAN PL-3601 Xbox 360(TM) TSZ...
I have a problem with my Wired Xbox 360 controller, it has four flashing lights when connected to the Xbox 360 console, and I cannot use it to play. It will turn on the console itself but will immediately...
You have to sync it. To do this you need to Press and and hold a tiny button in the front of the xbox next to the sd card slot for about 2 seconds. Then right afterward press a tiny button located on the top of the xbox controller. Its located next to the battery pack.
Jan 02, 2011 | Microsoft Xbox 360 S9F-00001 Wired...
Xbox 360 controlle not working
Have you tried pressing the sync switches on both devices, its the little white button on the top of the controller and the one on the 360 is near the memory card b slot (round white one) press the one on the controller and the lights shoudl start flashing then press the one on the 360 while the lights are still flashing they should then flash on one light about 3 times to indicate success. if this doesnt work you may have a faulty RF(radio frequency) unit, this is the wireless device which communicates with the controllers, if this is the case you can get this replaced at your local pc shop for around £20 to £30.
Hope this helps
Paul
Apr 02, 2010 | Microsoft Xbox 360 Controller
Controller will start up the 360, then just flashes. Wont respond
Remove the batteries from the controller for a few minutes to reset it then try again.
Jun 03, 2009 | Microsoft Xbox 360 Controller
Guitar hero 3 legends of rock my guitar doesnt work at all, the green light just keeps flashing on the guitar. please help thank you!
To fix this problem, when the game is in, wired guitar = plug in the remote, and it should work
Wireless= there should be a dot you are able to press in on, which will make the light flash green, then hit the button on your xbox 360 under the memory slots ----Besides * matters on how you have it laid out *
they will connect you to either 1st player * if your remote is turned off *
or second * if your remote is turned on *
let me know how it goes,
Thanks
Justin
Please Rate Me
Jan 16, 2009 | Activision Guitar Hero III: Legends of...
Xbox controls problems
Press the small button on the xbox 360 console then press the big X button on the center of the controller. Will make the controller and console pair up and work.
Sep 15, 2008 | Microsoft Xbox 360 Console
Xbox 360
Call Mircosoft Tech support you may have to send it in, its free though they send you a box free shipping takes 2-3 weeks depending on how many they are getting at the time.
Jan 28, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
