Question about Sony Dash Personal Internet Viewer HIDC10
Dash will not connect to my network. Keeps saying "wlan0 link is down, failed to obtain ip address internet is unreachable" Please help!!
My problem was my router's authentication type was set at "Shared". Once I changed it to "Automatic", I connected without a problem. I remembered this same issue with a new laptop that we couldn't connect to our WiFi. On the laptop, I went into the wireless properities & changed the security type to Shared. Unfortunately this isn't an option on the Dash, so you have to change it on the Router (using the router software). Hope this helps!
Posted on Nov 14, 2010
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
I'm using an SB5101 and trying to use a new wireless router with this modem, but the set up is saying I have a static IP address... where can I find that on my computer whil I'm using my old router? thanks
I have one, after finding out how reliable and well-made they are. However, they can be picky during setup, especially since they have a rare 'config IP' address (the number you type into your internet browser's address bar to change the modem's settings). Click here >> 192.168.100.1
See this link for more info.
Mar 21, 2011 | Arris SURFboard SB5101 Cable Modem
Why wont my acer netbook allow me to enter the network centre or to connect to virgin internet either wired or wireless. i'm running linux lite not windows
go to the command line and type ifconfig
find the network adapter you are trying to connect with likely eth0 or eth1 if ethernet or wlan0 for wifi
then type
dhclient wlan0 (or whatever adapter you're using.)
if this doesn't give you an ip address, the virgin internet access point may not play nice with linux.
Mar 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
My Toshiba Satellite Pro U400 has stopped connecting to the internet. Connectivity docotr says IP address needs to be set/was not set properly. Not my internet connection because other computer in the...
Your Toshiba Satellite Pro might be using a specified IP address. Try to set it to obtain an IP automatically. Depending on the Windows OS, whether it is XP, Vista or Windows 7, go to your Control Panel then Network connections or Network Sharing Center and double click on the Local Area Network connection (if your are using wired) or Wireless Connection. Look for the TCP/IP protocol and make sure it is enabled as "Obtain IP address Automatically" and "Obtain DNS addresses automatically". Then click OK to save settings.
Should you need further assistance, please let me know. Thank you for using FixYa.
Jan 31, 2011 | Toshiba Satellite Pro U400-S1001V Notebook...
Server unreachable
go to menu --> settings --> network configuration --> server menu and scroll down to server address and give the server ip address and save the settings and reboot
Mar 26, 2010 | Nortel i2004 IP Phone
I full signal strength from my rounter but wont connect
This could be due to wrong DNS settings or IP Address. You will need to go in to your network connections by doing the following: "Start, "Control Panel", "Network Connections" and then right click on your wireless connection and select "Properties", then when the new window opens scroll down to something called Internet Protocol (TCP/IP)
Open this by clicking "Properties" then adjust the settings as follows:
- Obtain an IP address automatically
- Obtain DNS server address automatically
Then configure your router to assign the IP Address and DNS Settings automatically and your internet should work.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | D-Link Computers & Internet
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
No ip address
when you say ip/config you mean wifi properties and internet protocol properties right ?
if so select obtain ip address auto and select obtain dns auto.
if thats not what you mean...goto control panel ..open network connections...click on ur network connection ...in the list at left select change settings for this connection...in network properties scroll to internet protocol..double click to open..select obtain ip auto and obtain dns auto.
there are other ways to fill in fields but you need relevant info..
there are programs which can show u ip's but most require a special driver.
incidently if you choose ip and dns auto you will not see ip address but when connecting to network you will see aquiring ip address please wait.
if for some reason you still cant connect go to a place where you know have free internet access and connect there then net connection will be configured
Jan 25, 2009 | Computers & Internet
Ip address wont work on ps3 anymore
It is likely your internet connection is not working properly.
Unplug your modem, router, PC, and power down your PS3.
Plug in your Modem.
Wait for it to run it's full diagnostics.
Plug in your router and let it do the same.
Power on your computer and let it obtain an IP address.
Then re-try your PS3.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2008 | Kenmore 46462 Front Load Washer
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Sony Dash Personal Internet Viewer HIDC10 Logo
1,732 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
