Question about Whirlpool MH1140XM Microwave Oven
Siwtch door stuck open,
I know it's probably hard to tell me, per se, what to do without seeing it, but any suggestions on how to fix the stuck door latch? I just spent 5 minutes comparing the top and the bottom latches and they look the same to me (I was trying to see if one was different so that I could maneuver one to look like the other).
    Genius:
  • 1,554 Answers
There is a switch on the front usually inside the back bottom latch it pushes on a switch in the back of it as you close the door.
you have to remove the top cover to get to it.
you can insert a plastic knife to test it. you should hear a click and light should turn off.
it may be jammed or open inside the switch .or wire is off. etc..
Posted on May 12, 2008
Door hard open
It sounds like the hinges are worn out or broken. Probably cheaper to buy a new one that to fix the old one.
Oct 15, 2014 | GE Advantium 120 Convection/Microwave Oven
Microwave displaying SE in the display panel, it is only 5 months old.
An SE error on a Samsung microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Jan 22, 2011 | Samsung MW1080STA Microwave Oven
My whirlpool microwave Gold's door is stuck shut. the button to open the door presses in without any tension and the door will not unlock or open
If this is an undercounter unit remove it from the mounts. Remove the case and look at the rear of the display/control area. You should be able to see the door latch. If not remove the electronics in that section of the unit. When you can see the latch you should be able to get the door open. If the unit is not working (latch wise) you will need to get a new one. Try www.repairclinic.com they have parts for everything at a good price. Getting the door lock out will require a little thinking on your part but you should be able to accomplish it. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Mar 03, 2010 | Whirlpool Microwave Ovens
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
I have a Kenmore model 665.68611891 micro. The door pops open
Per se there is no real adjustment, but the linkage that holds the two nylon hooks on the door in may need to be lubricated with some lithium grease made for nylon or neoprene parts. The sliding neoprene part that holds the hooks in place is not sliding all the way down into position. That part once you take the cover off is right up against the right front hand side of your microwave exactly inline with the two hooks and next to the control panel assembly. Take the cover off and manually opening and closing the door you will see how that part moves up and down to release and secure the door in place. You will be able to see where to apply the lubricant which should be anywhere two or more nylon or neoprene parts rub against one another. Let me know how it goes or if you need more guidance.
Feb 11, 2009 | Kenmore 62622 Microwave Oven
I cannot open the door of my Panasonic NN-T543W microwave
Well do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door closed. Anyway that is where your problem is. Let me know if you need more hlep.
Feb 09, 2009 | Panasonic NN-S251 Microwave Oven
Microwave, Panasonic model #NN-S951WF will not start. Electrical receptacles working. The fuse connected to the power cable has continuity. This has happened before but only briefly and when the unit...
If you have a display and the inside light comes on when you open the door, it won't be the fuse.
First, please press and hold the Start pad for about 4 seconds to see if the child lock comes on. (This is detailed in the owner's manual).
If it does, that means the pad on the keypad is okay, and you can press and hold Stop to turn it off.
If it does not, then you may have a bad keypad.
I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You are correct to suspect the door switches, especially if the Start pad is okay.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Or see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 21, 2008 | Panasonic NN-S951WF Microwave Oven
GE JE1540 replacement
This is usually caused by either a bad door switch or a loose door switch mount (which are pretty simple problems to fix).
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type from us for $5 postpaid.
If you still want to replace it, you can contact GE with your model number and they can probably tell you which model will be a "drop-in" replacement.
GE Customer Service is here.
Oct 21, 2008 | Microwave Ovens
Microwave runs but does not heat food either with sensor or manual timing. Occasionall will displasy 'SENSOR ERROR'. Have closed door and pressed CLEAR/OFF per manual instructions, but still does not...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
INFO: On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If the reset didn't fix it:
When you hit Start to cook, do the inside light and turntable come on?
Any unusual noises?
Is it louder or quieter than usual?
Do you have the model number?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Sep 07, 2008 | GE Microwave Ovens
Whirlpool MH1140XM Microwave Oven Logo
75 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
