Question about EdgeStar TWR181ES
Top compartment fan runs, does not cool. In fact, seems to be warming at display reads 77 when room temp is 70. Unit is located in the open, in the shade, and away from any heat sources. Bottom compartment works well with stable temp.
5 Suggested Answers
  • 4 Answers
SOURCE: Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Posted on Dec 29, 2007
eagle338
  • 4889 Answers
SOURCE: Freezer and fresh food compartment are warm.
The fridge thermostat is faulty and not cutting in at the required temperature. Fridge stats are not easy to test, so the best way is to bypass the stat to see if the compressor starts. To bypass the stat first unplug the appliance and remove the stat housing from inside the fridge compartment, once you have removed the housing you will see the stat inside. Some stats have 2 terminals some have 3, whatever yours has you will need to connect the compressor wire ( Black) to the live wire (Red or White). When you have bypassed the stat plug the appliance back in and switch on, if the fridge starts up and runs ok you will need to purchase a new stat.
Posted on Jul 17, 2008
  • 10 Answers
SOURCE: Fan blows room temp air, I can hear the AC kick in
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Posted on Sep 01, 2009
  • 910 Answers
SOURCE: I have a dwc283BLS wine
If the compressor is still running I would sugest that if you haven't had it serviced since you got it then it needs the coolant gas to be recharged.
You may just want to check the compressor and evaporator coils are clear from any dust as this would effect the operation of the chiller.
If you need any further assistance or clarification then please just ask.
Posted on Jul 19, 2011
My Duo-Therm AC on my 2001 Sandpiper Lite does not get cold in the afternoon win really starts to get warm. When it's on max the unit will barely cool and the seems to bog down fan slows down
check voltage coming in at that time also check see if air vents on faceplate open will cool that area close to get flow through unit check air temp coming out should be 20 degrees different from ambient room temp if not check fins on unit see if dirty if ok cooling unit going
Jun 20, 2016 | RVs
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
Room is warm 86 deg. unit runs, discharge temp is near 70 deg. unit runs for a while, will not bring room temp down.outside unit shuts off, i turn unit off, 1 hour and restart, it does the same.
The unit has a leak and is low on charge (freon) Find and fix leak, then vacuum and recharge...Leak is probably in flare fittings behind unit...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Mitsubishi MS24WN Air Conditioner
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
I have a Kenmore bottom fridge model #596.69274991. Although things are cold and frozen, the room temp is only 70 degree but it seem to run for well over an hour although there has not been much opening...
Tom, you pretty much have it all covered. Make sure both the freezer fan and the fan under the fridge are both running and keep your eye on the inside back wall of the freezer compartment fro any signs of frost build up (possible defrost problem).
Jun 12, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Maytag Sky box doeas not cool like it use to...... Lower compartments are colder than the top. Any info is greatly appreciated>thanks
This sounds like the compartment circulation fan is running slow. Check to see if it is running at full speed.
The circulation fan is supposed to run all of the time to keep the contents at an even temp. Also check the compartment door seals for damage. If the seal is damaged ambient air will cause the top of the compartment to warm up.
If you need help with manuals just respond here and I will get back to you.
Thanks for using FixYa.
Kelly
May 20, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Upright freezer quit cooling, interior fan runs, compressor runs
The coils are most certainly there probably located under your unit. Clean them thoroughly. Look under and to the very top of that space.
Jul 08, 2009 | Kenmore 50522 / 50524 Side by Side...
A/c doesn't remove moisture in the room? even when exchanger is set on open or closed--no moisture in collection tray either model #agj3211daxt2    G.E.
An A/C unit is a dehumidifyer BUT Unit are rated in Pints of water, a Unit in Florida might need a de humiditiyer connected to it, the air is heavy with humidity. Another reason is that the Unit is under sized or not allowed to run long enough (?) Infor. on what State you live in would help and the size of the apt. or house the unit is covering. The best T / H would be 70* and 55 H and that would be on the cool side for most people , avg temps in a house would be 74* 65%, body temps are 98.6 most A/C unit are rated at 90* amp temp ( outside ) if the condenser is dirty this will cut the performance on a hot day over 85* Keep unit clean -replace filter (s) . If your getting a 15 degree reading between outside and inside your doing good the best would be 20 degrees ( depending on heat load) windows, and sun. Actic fans remove 30% of the heat -it will drop the temp from 120 to about 85, this can save you a lot of money in A/C bills and help cool the house in warm day when you don't need the A/C.
Apr 27, 2009 | GE AGQ10AJ Wall/Window Air Conditioner
Kenmore 106.72102100 Not cooling URGENT!
behind the back panel that you pulled off is where the compressor is. on the left side of the compressor is where the relay/overload is plugged in. its gone bad. if you touch the compressor it will either be really really hot or room temp. unplug it let the compressor cool and replace the relay/overload to fix your problem
Nov 27, 2007 | Kenmore 65812
EdgeStar TWR181ES Logo
Top EdgeStar Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you an EdgeStar Refrigerator Expert? Answer questions, earn points and help others
