Washer does not drain good - Washing Machines
  • 156 Answers
Probley have the pump pluging up remove hose from pump and clean it out
Posted on May 12, 2008
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
Nd error code, what does this mean
ND stands for No Drain.
It means that either your drain is plugged, the piping inside your washer to the drain pump is plugged, your pump is damaged, your control panel is damaged or a combination of the above.
If you can hear your drain pump operating, you should check for blocked piping. If you have water in the washer, unhook your washer hose from the back of the washer and lower down to the floor to see if water drains from your washer. If little water runs out there is a good chance that the hoses inside your washer are plugged with something. If water runs out freely, then there is a problem with your pump that will not allow it to pump water up to your drain hookup.
Oct 04, 2014 | Samsung WF220AN Washer
Spin cycl isnt draining why
Good Morning friend, thanks for your post!
From my understanding your Electrolux washer is not draining. It could be the drain pump, motor, or control panel causing the problem with your washer not draining properly. I would schedule an appointment with a technician to come out and properly diagnosis your washer to avoid any unnecessary part purchases. -Matt
Oct 01, 2014 | Electrolux Washing Machines
Washer does not drain, how do i fix it?
Good Morning Friend,
I see that your Frigidaire washer, model# FEX831CS, is not draining. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still having trouble with your washer draining, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why your appliance will not drain. Hope this is helpful.
    -Best regards-
    WP
May 14, 2014 | Frigidaire FEX831CS Top Load Stacked...
Water coming out from under washer
What is the complete model number of your unit?
Nov 23, 2012 | Washing Machines
My washing machine will not drain...
Good Morning, Cindeyellis88:
3 weeks is a long time without a washer. Is the washer not draining for all cycles? Will it spin and not drain, or not spin AND not drain? Can you hear the motor running?
If the motor is running, and the machine will spin but not drain, you will need to open the machine and clear the hoses to and from the pump. There are YouTube videos showing how to open the machine safely.
If the pump is clogged, the problem may extend up to the tub. This happens when socks and small items go overboard.
Good Luck.
ChrMacKenzie
May 20, 2011 | Kenmore 22422 Top Load Washer
When washer spins out water backwashes out of the pipe onto the floor..
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Obviously your drain is blocked somewhere between your washer and your main drain. You might remove the rubber drain hose going from the washer to the drain pipe, then you could try using a plumbers snake in the drain to clear it. You probably have a clod of lint and strings built up in the drain. You might have to remove the first vertical piece of the drain in order to get the snake to work. Good luck.
Nov 23, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Washer won't fill up
The problem is most likely your drain. If there is no air break at the drain,( a gap where the hose goes into the pipe so air can enter) Your water will siphon out of the machine. Also make sure your drain pipe is higher than the tub of your washer and you only want about 6 inches of the drain hose sticking into the pipe. If you have water coming back out of the pipe when the machine drains, you will need a plumber to clean the pipes or replumb the drain. New washers pump out faster than older ones did and they need a good drain to handle the flow.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
