Question about Garden
I have a DurStar 7200 generator that has stopped running after 30 mins. The low oil light was lit on the control panel. I added a quart. Now it will not run more then 30 sec. Any suggestions?thanks Doug Book
  • 2,019 Answers
Since I believe the total oil capacity would be about 1.1 liter (not much more than a quart), you probably over filled it now.
When the low oil light comes on, it is supposed to stop.
Which it did.
So there was unlikely any harm.
But it probably still had half a quart in it, and not it probably have over 1.5 quarts.
If the piston can hit the oil, it will blow the bearings.
Unfortunately I can't find a manual to see capacity for sure.
And there is a diesel as well as gasoline version.
So all I can suggest is to drain all the oil, see how much you have in it, and put in just the right amount. There should be a full level or dipstick (probably with pint marks you mistook for quarts).
Posted on Sep 05, 2010
Testimonial: "thank you very much. That's probably exactly what I did but I'll fix it as you suggested tomorrow. "
I have a 1999 ford expedition. when I come to a stop, it starts to shake a little.
check the dipstick but I suspect that with 6 quarts ( gallon and a half)in an already filled sump that takes 4 quarts max is trouble in itself
coming to a stop and shaking indicates a vacuum leak or problem injectors
take it to an accredited service center , have the oil level adjusted and have the fault codes read
Feb 26, 2017 | Ford Cars & Trucks
I have a 200 ford expedition 5.4 liter and I can only check my oil level only if I have my truck and if its cut off my oil stick will not display any oil and the stick, only when its crank. I also have a...
02 sensors will not cause your vehicle to stall if they are bad enough to stall vehicle then your check engine light would be on. if the oil level only reads when vehicle running then ADD OIL ASAP. the level is very low. your dipstick checks level in pan once all oil drains back to pan with vehicle off. your oil is constantly flowing when vehicle running. that flow is splashing the oil up high enough that you are seeing it then. once truck is off all the oil drains down to pan and means level is so low not hitting the dipstick. If no reading when truck off you may need atleast 2 quarts of oil. Start by adding one quart to see if you get a reading. keep adding until you do. do not check immediately after shutting vehicle off. you have to give the oil time to drain back down to the pan. DO NOT KEEP DRIVING THE VEHICLE THAT LOW ON OIL YOU WILL BLOW YOUR ENGINE.
Sep 21, 2013 | Cars & Trucks
Kohler 30KW standby keeps throwing Under Voltage code - HELP PLEASE
The UV code has nothing to dow ith oil, poor oil would cause under frequency (low engine speed) Under voltage is caused by excessive load, short in the rotor/stator excition system, and/or AVR automatic voltage regulator. Of course loose wiring to will also cause it.
Feb 08, 2013 | Kohler 30 KW LP/Propane Industrial...
How many quarts of oil do u use when changing the oil?
check level after adding 4.5qts and running engine until the oil pressure light goes out (about 30 sec) then top off with another half a qt if low on the dipstick please rate
Aug 01, 2011 | 1991 Toyota Pickup
I have a Honda super quiet 6300i generator. It runs fine and then suddenly will stop. It restarts fine and there are no warning lights of any kind lit on the generator. What could be the cause and how...
Check the oil. Many of these units have a safety switch that will shut off the unit if the oil is low. It doesn't take much on some of these. Or, just add a little oil and give it a try, it certainly won't hurt it.
Jul 09, 2011 | Honda Electrical Supplies
I just purchased a used 2001 Crown Vic lx. today when i cranked it for the first time the oil light came on for about five minutes. i just put a quart in yesteday. after five minutes the light went off....
if it is just oil level sensor not too worry, other wise it sounds like you have low oil pressure most oil pressure sensors turn on lght below about 5-7 psi. its odd to me that light took so long to go out and are you running proper wt oil 10-30 say for your climate? most of the time engines warm-up oil thins a bit and so at low engine speeds, oil light comes on when engine is warm. one other thought was that you say it was running for 5 mins before oil light went out-did it sound bad? ticking or knocking like it really did not have oil pressure? or possibly sensor/gauge problem.
Jan 31, 2011 | Ford Crown Victoria Cars & Trucks
My eu 2000 watt generator (honda) starts fine, but consistently stops (like it is running out of fuel) after 10 to 30 minutes, then starts up and runs a while longer. I've taken the jet out under the...
My Honda generators have a low oil sensor that automatically shuts them down when a low oil level is detected. I keep a quart handy and top off the oil, and they start and run fine.
Dec 28, 2010 | Electrical Supplies
2007 rabbit - oil light
If it was still running okay & no noise, probably no engine damage. Adding 2 quarts should have turned off the light if the problem was oil pressure. Sounds like the oil pressure sending unit may be bad.
Apr 29, 2009 | 2007 Volkswagen Rabbit
I hv a colemanpowermate 5000/6250w generator- won't stay running
Hi, Please understand that this type of troubleshooting is hard without seeing it but doesn't sound like a fuel issue at all. This genset does have other sensors that will shut it down like low oil and high temperature. Most likely oil from your description. You also don't say what load it is carrying, could you be plugged into something that cycles off and on and when it cycles on the genset shuts down from the overload? If you think this might be the case, disconnect everything and power up a few at a time especially things that cycle on and off like refrigerators, heaters, stoves. Good Luck!
Jan 30, 2009 | Coleman Powermate Premium Plus 6250W...
Generator is stalling
My answer:
Not knowing your model # and how old your generator really is - as related to TOTAL RUN HOURS - I can only give you several possibilities of what the problem might be even though I don't know the make & model and what the rated WATTAGE output is.
I also don't know what LOAD you are putting on the Genset or at what RPM you are running the engine at as to half throttle or full throttle setting?? I take it that it's a Briggs & Stratton 4-stroke single cyl, or is it a Honda 4-stroke single/twin cyl engine?
Since it runs good for 30 mins, and then starts to cut out - I doubt that the OIL is a problem even though you ran straight 30 weight - seeings most small engines run 10-30 weight oil as a rule.
I seriously doubt you did any damage to the engine at all unless it was ran low on oil - in which case it should have a LOW OIL cutoff switch mounted in the lower engine case close to the CHECK OIL port.
If the LOW OIL switch is working properly and adjusted properly then you shouldn't be getting cutout unless this switch is mis-adjusted. (ie: mechanically set too low as then when the oil level is indeed at it's proper level the switch would be already shorting out to ground) (See your operators manual for proper setting)
A way to check for proper operation is to temporarily disconnect the (usually) BLACK wire from the LOW OIL switch when the engine starts to cut out. If the problem goes away completely then the LOW OIL switch is either mis-adjusted or else it is going bad from vibration. (Again see your operators manual for proper adjustment and/or check out procedure)
Electronically this LOW OIL switch should be the only thing that would protect the engine from damage should the oil level fall below recommended level. Other then that it may have an electronic REV LIMITER if it's a bigger and more expensive model, but usually not.
I doubt the Maintenance-free Magnetron® electronic ignition is at fault, but could be weak and going bad. Always a possibility, but I would 1st rule out everything else first. Since the Genset runs for 30 mins and then starts to cut out I would look more for like a fuel vapor lock (partially closed or clogged gas cap vent), a possible dirty fuel filter, possible water moisture in the gas tank or in the carb bowl, possibly dirty carb in general along with it's dirty Float Bowl, Float Pin, Float and Needle Valve, and any Adjustment Screws that go Into the Carb Body. That covers everything from a fuel standpoint.
You do know that all Gensets should be started and run for at least 10 mins every 30 days - right? If you didn't know this - now you do! Every good operators manual should state this.
It just doesn't sound like it's starving for gas unless it's building up a (vacuum) or vapor lock in the gas tank.
Having covered everything from an Electronics/electrical standpoint engine wise - there is only one other thing left Genset wise.
What it really sounds like to me (and I personally HAVE SEEN this happen myself firsthand) is that the generator brushes are nearly shot - as in almost worn out. They may be getting too too hot - as from excessive current draw at point of contact, and thus the generator sensing circuitry itself is doing an electrical CUTOUT!!
An added protective Genset circuit feature in that the generator itself may indeed be linked to the engine as a type of REV LIMITER on the Maintenance-free Magnetron® electronic ignition. Again - your operators or service manual should have a pretty good troubleshooting section in it unless you don't have that anymore or never got one if you bought it used to begin with.
It has to be one of the scenarios listed above.
Please post me a reply as to the found problem there, and the resolve to it by following my recommendations above. Also please rate my troubleshooting fix as well.
Best regards and thanks,
Frank
Sep 01, 2008 | Coleman Powermate Premium Plus 6250W...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
