Excel in excel make a prog ans come as 2250 how it automaticall come in english astwo thousand fifty
  • keshave May 12, 2008
    means that how 2250 autonaticall come in words
    Novelist:
    Champion:
  • 214 Answers
First a question - is this school homework?
I ask because I have just spent about 2 hours on creating the answer - there is no function to do this except to convert to text as currency in Thai.
Posted on May 12, 2008
  • Les Clayton May 12, 2008
    I just found this (I haven't tried it):
    Here is a very popular bit of code from Microsoft that will convert any number in a cell to English words. All code and text from below here is the work of Microsoft.
    Summary
    This article contains sample Microsoft Visual Basic for Applications functions that you can use to convert a numeric value into its equivalent in English words. For example, you can change 32.50 into "Thirty Two Dollars and Fifty Cents" by entering the following formula into a cell:
    =SpellNumber(32.50)
    You can also use these functions to refer to other cells in the workbook. For example, if the number 32.50 was in A1, you could type the following into a cell:
    =SpellNumber(A1)
    The Function Wizard can also be used to enter a custom function in a worksheet. To use the Function Wizard, follow these steps:
    1. Click the Function Wizard button, and select User Defined under Function Category.
    2. Select SpellNumber, and enter your number or cell reference.
    3. Click Finish
    To Create the Sample Functions
    1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
    2. Type the following code into the module sheet.
    Option Explicit
    ' Main Function *
    Function SpellNumber(ByVal MyNumber)
    Dim Dollars, Cents, Temp
    Dim DecimalPlace, Count
    ReDim Place(9) As String
    Place(2) = " Thousand "
    Place(3) = " Million "
    Place(4) = " Billion "
    Place(5) = " Trillion "
    ' String representation of amount.
    MyNumber = Trim(Str(MyNumber))
    ' Position of decimal place 0 if none.
    DecimalPlace = InStr(MyNumber, ".")
    ' Convert cents and set MyNumber to dollar amount.
    If DecimalPlace > 0 Then
    Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _
    "00", 2))
    MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
    End If
    Count = 1
    Do While MyNumber <> ""
    Temp = GetHundreds(Right(MyNumber, 3))
    If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
    If Len(MyNumber) > 3 Then
    MyNumber = Left(MyNumber, Len(MyNumber) - 3)
    Else
    MyNumber = ""
    End If
    Count = Count + 1
    Loop
    Select Case Dollars
    Case ""
    Dollars = "No Dollars"
    Case "One"
    Dollars = "One Dollar"
    Case Else
    Dollars = Dollars & " Dollars"
    End Select
    Select Case Cents
    Case ""
    Cents = " and No Cents"
    Case "One"
    Cents = " and One Cent"
    Case Else
    Cents = " and " & Cents & " Cents"
    End Select
    SpellNumber = Dollars & Cents
    End Function
    ' Converts a number from 100-999 into text *
    Function GetHundreds(ByVal MyNumber)
    Dim Result As String
    If Val(MyNumber) = 0 Then Exit Function
    MyNumber = Right("000" & MyNumber, 3)
    ' Convert the hundreds place.
    If Mid(MyNumber, 1, 1) <> "0" Then
    Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred "
    End If
    ' Convert the tens and ones place.
    If Mid(MyNumber, 2, 1) <> "0" Then
    Result = Result & GetTens(Mid(MyNumber, 2))
    Else
    Result = Result & GetDigit(Mid(MyNumber, 3))
    End If
    GetHundreds = Result
    End Function
    ' Converts a number from 10 to 99 into text. *
    Function GetTens(TensText)
    Result = "" ' Null out the temporary function value.
    If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19...
    Select Case Val(TensText)
    Case 10: Result = "Ten"
    Case 11: Result = "Eleven"
    Case 12: Result = "Twelve"
    Case 13: Result = "Thirteen"
    Case 14: Result = "Fourteen"
    Case 15: Result = "Fifteen"
    Case 16: Result = "Sixteen"
    Case 17: Result = "Seventeen"
    Case 18: Result = "Eighteen"
    Case 19: Result = "Nineteen"
    Case Else
    End Select
    Else ' If value between 20-99...
    Select Case Val(Left(TensText, 1))
    Case 2: Result = "Twenty "
    Case 3: Result = "Thirty "
    Case 4: Result = "Forty "
    Case 5: Result = "Fifty "
    Case 6: Result = "Sixty "
    Case 7: Result = "Seventy "
    Case 8: Result = "Eighty "
    Case 9: Result = "Ninety "
    Case Else
    End Select
    Result = Result & GetDigit _
    (Right(TensText, 1)) ' Retrieve ones place.
    End If
    GetTens = Result
    End Function
    ' Converts a number from 1 to 9 into text. *
    Function GetDigit(Digit)
    Select Case Val(Digit)
    Case 1: GetDigit = "One"
    Case 2: GetDigit = "Two"
    Case 3: GetDigit = "Three"
    Case 4: GetDigit = "Four"
    Case 5: GetDigit = "Five"
    Case 6: GetDigit = "Six"
    Case 7: GetDigit = "Seven"
    Case 8: GetDigit = "Eight"
    Case 9: GetDigit = "Nine"
    Case Else: GetDigit = ""
    End Select
    End Function
    To use this UDF push Alt+F11 and go Insert>Module and paste in the code. Push Alt+Q and save. The Function will appear under "User Defined" in the Paste Function (Shift+F3).
    My own solution involveed IF statements (etc) and though it worked, the solution above may be easier.
Explain how to write 50,000 using exponents
5 X 10 to the 4th. The 4th is a superscript of 10, written to the top right of the zero in 10.
The expression Ten to the 4th means ten multiplied by itself 4 times.
10 to the 4th is 10 X 10 X10 X10.
Ten multipled by itself four times equals ten thousand.
5 X 10 X 10 X 10 X 10 equals fifty thousand.
Five times ten thousand is fifty thousand.
The link belows discusses the terms base and exponent and provides examples.
Crestview Middle School
Aug 28, 2017 | Office Equipment & Supplies
Write 139,852 in word form
One hundred thirty nine thousand eight hundred and fifty two
Sep 20, 2016 | Computers & Internet
Idling speed is 2000rpm for ever
Hi Cathy, some vehicle need replcement every one humdred thousand kilometes others have extended to one fifty. Stay safe go for a hundred. (about sixty thousand miles) regards Johngee10
Nov 14, 2011 | Cars & Trucks
My manual isnot in english i am english
Hi, I'll try to help you, I checked on the singer website for a instruction manual & it show they have one that's free downloadable in PDF form
just follow the steps
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 2250) & click search
the second one is free
Sep 10, 2011 | Singer 2250 Tradition
How much will I spend on changing seals, clutch, and timing belt on a 1998vw golf gti 2.0?
i know for the clutch it will be like a thousand bucks or more timing belt maybe like fifty bucks and the seal maybe like another fifty bucks that how much it cost me on my honda civic so good luck
Jan 04, 2011 | Volkswagen GTI Cars & Trucks
Can I get a manual for a singer serenade 2250 in English
Hi
Try on the Singer website. Just type 2250 in the search box and then click search. http://www.singerco.com/accessories/manuals.html
The model name is tradition instead of serenade but it seems to be very similar to your machine. Hope this helps!
Sep 04, 2010 | Singer 2250 Tradition
I NEED MS EXCEL CONVERT FORMULA FOR NUMBER TO CURRENCY
Here is a very popular bit of code from Microsoft that will convert any currency amount in a cell to English words. All code and text from below here is the work of Microsoft.
Summary
This article shows you how to create a sample, user-defined function named ConvertCurrencyToEnglish() to convert a numeric value to an English word representation. For example, the function will return the following words for the number 1234.56: One Thousand Two Hundred Thirty Four Dollars And Fifty Six Cents
2. Select ConvertCurrencyToEnglish, and enter your number or cell reference.
3. Click Finish
Function ConvertCurrencyToEnglish (ByVal MyNumber)
Dim Temp
Dim Dollars, Cents
' Convert MyNumber to a string, trimming extra spaces.
' Find decimal place.
' If we find decimal place...
' Convert cents
Temp = Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2)
Cents = ConvertTens(Temp)
' Strip off cents from remainder to convert.
End If
Count = 1
' Convert last 3 digits of MyNumber to English dollars.
Temp = ConvertHundreds(Right(MyNumber, 3))
' Remove last 3 converted digits from MyNumber.
Else
MyNumber = ""
End If
Count = Count + 1
Loop
' Clean up dollars.
Select Case Dollars
Case ""
Case "One"
Case Else
End Select
' Clean up cents.
Select Case Cents
Case ""
Cents = " And No Cents"
Case "One"
Cents = " And One Cent"
Case Else
Cents = " And " & Cents & " Cents"
End Select
ConvertCurrencyToEnglish = Dollars & Cents
End Function
Private Function ConvertHundreds (ByVal MyNumber)
' Exit if there is nothing to convert.
' Append leading zeros to number.
' Do we have a hundreds place digit to convert?
If Left(MyNumber, 1) <> "0" Then
Result = ConvertDigit(Left(MyNumber, 1)) & " Hundred "
End If
' Do we have a tens place digit to convert?
Result = Result & ConvertTens(Mid(MyNumber, 2))
Else
' If not, then convert the ones place digit.
Result = Result & ConvertDigit(Mid(MyNumber, 3))
End If
ConvertHundreds = Trim(Result)
End Function
Private Function ConvertTens (ByVal MyTens)
' Is value between 10 and 19?
If Val(Left(MyTens, 1)) = 1 Then
Select Case Val(MyTens)
Case Else
End Select
Else
' .. otherwise it's between 20 and 99.
Select Case Val(Left(MyTens, 1))
Case Else
End Select
' Convert ones place digit.
Result = Result & ConvertDigit(Right(MyTens, 1))
End If
ConvertTens = Result
End Function
Private Function ConvertDigit (ByVal MyDigit)
Select Case Val(MyDigit)
Case 1: ConvertDigit = "One"
Case 2: ConvertDigit = "Two"
Case 3: ConvertDigit = "Three"
Case 4: ConvertDigit = "Four"
Case 5: ConvertDigit = "Five"
Case 6: ConvertDigit = "Six"
Case 7: ConvertDigit = "Seven"
Case 8: ConvertDigit = "Eight"
Case 9: ConvertDigit = "Nine"
Case Else: ConvertDigit = ""
End Select
End Function
Apr 15, 2010 | Broderbund Learn MS Windows XP and Excel...
Create an inventory prog. in visualbasic?
Do you have Microsoft Office? There are some excellent Access Templates for Inventory Databases
Jan 13, 2009 | Microsoft Windows Vista Ultimate Edition
Indian Rupee format in Excel spreadsheet
Rupees with Paise
[>9999999]"Rs. "##\,##\,##\,##0.00;[>99999]"Rs. "##\,##\,##0.00;"Rs.
"##,##0.00
Rupees without Paise
[>9999999]"Rs. "##\,##\,##\,##0;[>99999]"Rs."##\,##\,##0;"Rs. "##,##0
Rupees without Rs. notation
[>9999999]##\,##\,##\,##0.00;[>99999]##\,##\,##0.00;##,##0.00
Sep 14, 2008 | Microsoft Excel for PC
How to convert my numirecal velue into text
There is no standard function for doing this in Access 2003, you will have to write a function yourself, or have someone do it for you.
Jun 28, 2008 | Microsoft Office Access 2003 (077-02871)...
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
