Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
Samsung 80 gb Hard Disk Un allocated
3 Times I got the same problem. I am using 80 gb hdd as master and another 40 gb samsung as slave. I tried another sata hdd to instal by removing 80 gb hdd. After finished sata installation when again I tried to start pc using 80 gb as master it couldnt start. by making its a slave when i tried by another hdd then at Computer management of 2000 server i saw the harddisk has no singnature. then i ensure singnature but no partition. then i shall have to make new partition and lost all the data. Before this 2 times i faced the same problem. Samsung dealter replace hdd with new one but i had to lost my valuable data. And at my office i am still using 80 gb samsumg as 32 gb. the pc is pentium 3 500 mhz HP. Now I am afraid to Samsung Hdd.
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
Posted on Jul 19, 2008
Hello. I use Intel ZX-865 GV Motherboad with three hard disks- Maxtor 20 GB Hard Disk,Samsung 80 GB Hard Disk & Hitachi 500GB Hard Disk. Problem is,the motherboard often can not detect one hard...
As the error says, the 3rd slave hard disk (which one depends on how you have connected them - most likely the Samsung) isn't responding in a timely manner to the commands coming from the southbridge. Because of the miscommunication, the master disk on the same cable (the Hitachi) can also fail the recognition, even if there is nothing wrong with it.
This is a hardware defect: that disk is dying and there is nothing you can do to fix it. Just take out all your information out of it and remove it from the pc permanently
Jul 22, 2011 | Intel D865GBF Motherboard
Compaq Presario will not format Samsung 80GB hard drive.
Sir,
you are required to follow these steps below.
1 turn on your computer with HDD in it
2 Enter in to the BIOS by pressing F2 button
3 there entering in BIOS look for "Drive Configuration" it might be writen in some other words
4 there you will find ..."Hard drive SMART capacity" as enabled in box above.
5 Enter that box and Disable it.
6 Push F10 and reboot the machien.
Now you will be able to format , install etc on your hard drive hopefully
Oct 21, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Problem in hard disk
control panel
computer management
disk management
select the disk and iniatlize by right clicking.
Jul 09, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Samsung SP0802N 80GB Slave
Go into the control panel. Press administrative tools. Select computer management. Under storage select disk management. Look for the hard drive. Make sure there isn't an additional partition on the drive. If there is you can change and delete partitions on this drive as well.
Jan 03, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Removing bad secter from hdd
there are vaious ways
if u know how to make it slave hdd make it one by one on any desktop and run a disk defrag and scan along wd the consistancy check it is a time consuming process
ill suggest to format them it will take 20 min/hdd
May 19, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Problem in Harddisk
Does it make any sounds like any of these?
Does it spin up at all?
Apr 29, 2008 | Samsung (SP0822N) 80 GB Hard Drive
SP0812N HDD 80Gb
this mainly depends on The Operating system, if your using Windows 2000 or above it should,nt be an issue.
sometimes there are limitations on 2 hard-drives sharing the same IDE channel on the mainboard.
Try putting the second hard-drive on the secondary motherboard slot, with it,s own individual cable.
If non of the above works, it,s possibly not formatting correctly.
you,ll need a program that zeros then formats the drive.
Hope this helps.
Mike @ Compurepair.
Feb 22, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
SAMSUNG IDE HDD SP0411N (40GB)
Three possible reasons:
1. Your IDE cable is defective or is not seated/plug in correctly. Try to replace or re-seat/re-insert;
2. The on-board disk management of the hard disk is corrupted/defective. There is no remedy except to replace the PCboard or the entire hard disk;
3. Your motherboard BIOS/CMOS needs to be flashed and/or something is wrong with the IDE interface.
Of the 3, # 1 is the most common.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Jan 06, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
391 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
