Question about BOSS AUDIO SYSTEMS 815CA
BOSS AUDIO SYSTEMS 815CA : Radio was installed by cartonics, but i just noticed that the cd player doesn't work. Could it be a wiring problem? What should I check for?
  • 1 more comment
  • ameasa Sep 05, 2010
    Please be advised that the radio is brand new, never used.
  • ameasa Sep 07, 2010
    BOSS AUDIO SYSTEMS 815CA : Brand New Radio was installed by cartonics, but i just noticed that the cd player doesn't work. I tried to load a cd but it had no power and i don't hear any movement internally. Could it be a wiring problem? What should I check for? I have a 1997 ford expedition.
    Thanks for taking time out to answer me. The radio is new, i got it on amazon.com. The radio works great and the aux too but the cd player is dead. Are there any color wires that should be hooked up also to make the cd player work? Cartronics is the company that installs radios, alarms etc...
    Guru:
  • 632 Answers
Not really it was a wiring issue nothing else would work, Either laser has gone wrong and is not reading disks Or the motor which spins disk when inserted is broke
Take it back to cartonics and let them look as you should be covered under there guarantee if its been bought from them and broken even when you didn't fit it they did also.
Posted on Sep 07, 2010
  • Simon Swales
    Simon Swales Sep 07, 2010
    Not really the stereo has a broken CD unit
    You could send it back and get it replaced
    You can remove it yourself with a radio remover key to insert into sides to slot it out
    then unplug the connectors cartonics did for you can get it replaced under warranty then
    you can refit your old one exactly how it was and will be working again.
  • 857 Answers
There is nothing much you can do on your own. There is some internal psoblem It will need to be opened and cleaned up by a tech.
The laser assby and the rails it runs on need cleaning
Either a TV or stereo repair service could do it
Posted on Sep 05, 2010
  • Jayant Jha Sep 05, 2010
    OK in that case you can simply call the manufacturer. If it is a manufacturing defect they will replace it for you.
What am i doin wrong with my boss radio? when i set a station when i shut the engine off i loss my settings
Sounds like your Memory +12V wire is not connected properly. If this wire does not have a constant source of power then you will lose all of your settings on your radio.
Things that may cause you to lose power through the Memory 12V wire:
  • Not hooked up properly to the battery
  • Bad battery
  • Bad ground
  • Loose wires
Boss 637UA manual
Sep 04, 2014 | BOSS AUDIO SYSTEMS BOSS 637UA - radio / CD...
Wire color chart
The wiring diagram is on page 12 of this manual.
Feb 05, 2013 | BOSS AUDIO SYSTEMS 514CA Car CD/ MP3...
How to install Boss audio systems AVA 1210
I tried to install my boss Ava 1210-7 equalizer but I have a 2din001 radio i have a rca jack plug at the back of the radio say AV in its 3 jacks red,white and yellow. I only connect a rca jack to the red and white and leave out the yellow one when I put that to my EQ CD rca section it doesn't work I don't know what to do next! Can someone help Out?
The picture is the rca jack section from the back of my radio
Mar 05, 2012 | Boss Car Audio & Video
How install?
. I have a Boss 612UA. When I plug it in it gets very hot in the back of the unit near the plug. I checked the wiring and it is correct.
Nov 13, 2011 | Boss Multimedia Player 612 UA
How do you update the software for a boss 638UA car stereo
Software for car radio usually can't be updated. If Boss have a new firmwire, you can go to their website and install it via USB.
Feb 28, 2011 | BOSS AUDIO SYSTEMS 638UA Car USB Player
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
Boss bv7985
there should be a wire they wanted you to hook to the parking brake as a safety feature so you cant drive and watch tv. but you can just take that wire and ground it to your black ground wire on your radio that should give you your pic
Mar 09, 2009 | Boss AUDIO SYSTEMS BV7985 Car DVD Player
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
May 20, 2008 | Boss DVD-7500 Car DVD Player
BOSS AUDIO SYSTEMS 815CA Logo
50 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
