APC XS 1000 UPS battery back up beeps three times every minute. "see manual" "AVR" flash in screen.
    Sergeant:
  • 311 Answers
It is SUPPOSED to beep during battery supply power.
It drove me nuts,too!
I know it's running off of the battery!!!!!!
I have APC 550 and a 750. Both do it.
Not anymore.
I took it apart and mangled the beeper,inside.I used a dental pick and poked the diaphram inside of it.(power off)
Clicks,but no BEEP!
Barely audible,now. Done.
Posted on Feb 15, 2014
Battery signal flashing
in some UPS model, battery flashing is just an indication that the batteries are not fully charged. there is problem is the flashing LED is red in colour
Jun 23, 2012 | APC BX 1000 Back-UPS XS 1000 (APNBX1000)...
I have an APC XS 1500 UPS. We recently had a power outage and now the display states "event 9" and the unit beeps every 15 minutes or so.
This "Event 9" means that the UPS has has 9 events. It could be going on battery or a high input or output. Either way we can reset it. You will have to turn on the UPS. Unplug it from the wall and also unplug the battery. When all is unpluged push and hold the power button for a few seconds. This is the reset. once done hookup the batteries and plug in the ups. All should be better. Event 9 will be gone. Till next time..... When it will say "Event 10"
Sep 11, 2011 | APC TM) Back-UPS XS Series Battery Backup,...
I have an APC XS 900 for about 1 1/2 now. I started getting a continuous beep with the overload light turning on. I could not get it to stop, even when the computer was disconnected. After reading the...
You need to reset the unit to recognize the new battery, I had same problem with one apc smart ups on the bench the other day.
On ours we had to turn off the unit unplug the battery wait 5mins
press the on key and hold for 20secs
reconnect battery
plug in to mains
and start as normal. We did this but still had very low battery time and the flashing lights, so we disconnected the comms interface, that sovled the problem.
It may work for your unit, suggest you check the manual before you try if you are unsure
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | APC Back-UPS XS900 (BX900) UPS System
Infinit loo between online and on battery?
With all 5 units behaving the same, I would expect that the power is still out of range. If the power is too high or too low (see manual for thresholds) the unit will stay on battery power to protect the attached equipment. If you have the software loaded, it will show you what the input AC voltage is at. Otherwise, it could be time for new batteries: http://batteryinternational.com/apc-smartups-1000-ups-battery-ups-batteries-f2.html
May 09, 2010 | APC Smart-UPS 1000VA UPS System
I have an APC XS1300. One year old. Very few
Mines, two or three years old and doing the exact same thing, you ever figure out what happen or how to fix it? I took the battery out and it reads 16 volts. I put a 2 amp load (fan) on it and it pulls fine, so I'm reluctant to buy a new battery pack for it now.
Feb 01, 2010 | APC BACK-UPS XS 1300VA LCD 120V...
Have brand new APC 900 UPS and when plugged in, both green & yellow indicator lights flash. Non-stop. Left unit plugged in for 18 hours (off) to charge battery as info sheet suggested, but lights still...
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
Sep 19, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
Overload light lights and unit beeps. It is not pluged into power and nothing is pluged into the unit.
It sounds like the battery is compatible with the ups.
However, APC has excellent free phone support.
I recommend that you give them a call.
Be ready to give them the model number and serial number for your UPS.
(800) 555-2725
Please vote for my solution if it helps you solve your problem.
Sep 05, 2009 | APC BX 1000 Back-UPS XS 1000 (APNBX1000)...
Ran for about 15 minutes. Hooked up to one
Ether the unit is overloaded or the internal battery is given out, or the overload circuit has failed there are only 3 problems that it could be. Not to go to much in depth on this unit APC does have a garentee and I trust you will call them and tell them this exact same issue if they find the unit is faulty they will replace it even though it may be out of warrenty if you get them on the phone and explain to them they will help I know a Greg over there.
Aug 12, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
Want to replace batteries in my ups
APC BX1000 UPS.
First analyse with local UPS service engineer to find out the problem is related with UPS.
It requires 12 Volts batteries for this UPS Usage.
The batteries required are 2 Numbers.
Buy these batteries from authorized APC Vendors and these batteries are having 1 year warranty.
In case of any problem, these batteries will be replaced at free of cost.
To close this solution, please get in touch with Authrzed UPS Service Engineer.
Jul 11, 2009 | APC BX 1000 Back-UPS XS 1000 (APNBX1000)...
Computers & Internet Logo
427 people viewed this question
David Payne
David Payne
