Question about Toshiba 43H72 43" Rear Projection Television
Green and pink double vision on my tv
My hd toshiba 43h72 I have had it for 5years and now it is showing green and pink and double vision. Please tell me what is going on with my tv
  • 4,234 Answers
This is a convergence problem. Try resoldering the pins on the convergence ICs. These are large black ICs attached to a heatsink. They should have about 15 pins and be marked STKxxx. If the resoldering does not resolve the problem, replace the ICs. These should cost about $15-$25 each.
Dan
Posted on May 12, 2008
Upper left corner of tv is double image with pink and green
Press Menu on the remote If you see double green, red or blue letters and a part or all of picture looks double, this means the convergence circuit is the problem. A repair like this could be $150.00 and up.
If you're an electronic savvy, you can replace the two chips (stk392-***) yourself.
In this case the 2 black big convergence (both with same part#) chips need to be replaced and without the model# I can't tell which ones they are but they could be one of the following: STK392-110 or STK392-120.
Sometime the resistors around the ICs go bad and you inspect them and measure the with an ohmmeter.
Best of luck
www.aaatvservice.com
May 06, 2012 | Hitachi 51F710 Rear Projection Television
We are seeing green and pink upper left corner and today it looks like double vision
There's a possibility that you place your tv set in a strong magnetic field. eg. large electric motor. speakers. try reposition your tv set
Jun 26, 2009 | Hitachi 50DX01B 50" Rear Projection...
Jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. digital-dump@hotmail.com
Dec 21, 2008 | JVC HD-61Z575 61" Rear Projection...
Left side of screen going yellow and pink with leters in double
The convergence modules have gone bad Along with the new parts kit are fuses, diodes, and resistors that usually fry when these modules go bad. Depending on the model, there will be two and sometimes 3 of these modules that have to be replaced. Each module has 50 pins each that have to be soldered, so unless you have experience with complicated TV repairs, the cost to do that repair may be as much as a flat screen TV of the same screen size as yours.
May 12, 2017 | Mitsubishi WS-65711 65" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Line at top of screen
There are problems in the vertical blanking or scanning circuits. This is not something you can fix yourself at home. It involves troubleshooting the deflection amplifiers and scan generator areas to locate the defective components.
You will have to give the set out for service. I would suggest to get an estimate before proceeding. This type of repair can be costly for the labor to find the fault. If it is only generic type parts involved, the parts themselves will not be too expensive.
Jerry G .
Jul 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Toshiba 43H72 43" Rear Projection Television Logo
191 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
