Question about Dryers
I purchased a new WED9400SU electric dryer and it work fine for a few cycles but all of a sudden the start button does not light up and therefore it will not start no matter what I do. I've unplugged all to no avail.
    Master:
  • 788 Answers
If the machine thinks the door is opened then it won't let you start it. Here is a link to the door switch: http://www.partselect.com/xq/aspx/Inventory.1487995/qx/PartDetail.htm?SourceCode=5&ModelNum=WED9400SU You could also try opening the door and activating the switch or even wiggling it to see if the start button light flickers. If the switch looks OK you may have a problem with the electronics. Or if there is a solder joint or cable break problem it may run fine until it gets hot.
Posted on May 12, 2008
    Sergeant:
    Champion:
  • 230 Answers
Have you ever pulled your clothes out of the dryer and found them to be scorching hot? This sensor helps alleviate over drying and under drying, and helps save energy. The way the sensor works is that as wet clothes tumble past the sensor (two smooth stainless steel protuberances) they gauge the degree of moisture in the clothes by the resistance they offer. This function only works in the automatic mode, but you can still access the information on the control panel about how dry the clothes are while using the timed dry. The sensotronic sensor requires a monthly wipe down with a paper towel and white vinegar to nullify any build-up and keep it working properly
    President:
  • 2,712 Answers
Hello dcorbett,
Most likely it is a problem with the thermal fuse. An open thermal fuse kills power to the motor circuit in most dryers.
However, try these troubleshooting steps first:
Has a household fuse blown or has a circuit breaker tripped? There may be 2 household fuses or circuit breakers for the dryer. Check to make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse or reset the circuit breaker. If the problem continues, call an electrician.
Is the correct power supply available? Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but not be latched. Push on the door to engage the latch or latches.
Duet® Dryers have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start or Hold to Start button firmly pressed?
Large loads may require pressing and holding the Start button for two to five seconds.
Is the Cycle Control knob set on an Automatic Dry or Timed Drying cycle?
The Cycle Control knob must be set in an Automatic Dry or Timed Drying cycle. The dryer will not start if set on Wrinkle ShieldTM control setting.
Is Control Locked status light on (on some models)?
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
Did you recently install a power supply cord on the dryer?
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
If the above steps did not correct the problem, it is most likely the fuse. If you know how, it should not be too difficult to replace it. But since you said your machine is new, the best recommendation I can provide is to contact your manufacturer or point of purchase and get them to take a look/replace the dryer. Opening up the machine could void the warranty.
You can contact Whirlpool customer support HERE.
Hope that helps! Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 18, 2008
    Just checking to see if your issue is resolved. If it is, please assign
    a Fixya rating for the Expert whose advice guided you to a fix.
    Cheers!
  • Dryers Master
  • 13,433 Answers
Since its brand new contact your dealer right away!
I suppose you have tryed to change the settings on it and it still doesnt light up? in that case go ahead and contact your dealer, they will replace it or repair it.
    Brigadier General:
  • 6,966 Answers
Have you checked the fuses and/or the breakers of the outlet where it is plugged? Additionally, the unit would have its own fuse, pls try checking that likewise.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 13, 2008
    Or try plugging the unit into another power source/outlet (of course that can supply the needed voltage/amperage).
  • 3,037 Answers
Alright, make sure that the door switch/sensor isn't broken and that it is closing all of the way. Try turning the dial on the dryer around a few times and seeing that it clicks and try it in a different cycle and see if it starts.
let me know if this still doesn't work and we can try a few other things. If it is new and you find something that is damaged then it can probably be taken back and swapped. Also, your warranty might also cover a house visit to check it out if it still won't work after doing the above which I would look into by giving the place a call.
Please let me know what you do and check and whether it helps or not and I will give you a few other things you can do, thanks
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    Please don't forget to let me know your thoughts about my
    solution.
    If your problem is fixed, please rate this solution as that is one of the
    biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to
    help.
    Thank you
My dryer initially makes a buzzing sound and will not begin the cycle until I give it a few turns manually...
you have a bad motor,if you open the door,hold the door switch in with one hand and spin the drum with the other and have someone else push the start button on and if by helping it to spin it starts usually the motor is bad but i did find on the maytag neptune style dryer that the belt cut into the belt pulley and was holding up the drum and the motor was buzzing like it was bad but like i say usually it's the motor.next time send the brand name and model number and i can help you out better.
Jan 25, 2014 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet GEW9250 Dryer; Only Running in Delicate Cycle
that knob is actually a switch. fixing it will be much easier, if you replace the whole switch unit..
good luck..
Jan 29, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer start up fine then the gas turns off as ignitor continues
Hi Jim. Perhaps this will help you.
The burner assembly consists of the gas valve, the igniter and sensor, and the thermostats. The gas supplied to the appliance is turned on and off by the gas valve, as follows:
  • First--when you close the dryer door, set the timer, and press or turn the Start button--the motor starts. When it reaches full speed (in about a second) a switch on the motor turns on, which allows the electricity to flow through a simple thermostat to one side of the gas valve.
  • The gas valve then sends power to the igniter, which glows bright orange.
  • As heat and light from the igniter warm up a sensor that's right next to the igniter, the sensor circuit opens, then supplies power to the other side of the gas valve. This completes the circuit and opens the valve.
  • Once the valve opens, the gas rushes out and the igniter ignites it. As the gas burns, it keeps the sensor warm, which keeps the gas flowing.
  • When the dryer reaches the pre-set drying temperature, a simple thermostat turns off the flow of electricity to the gas valve and therefore turns off the gas.
  • When the temperature in the dryer falls about 20 to 30 degrees, the thermostat again allows the electricity to flow through to the gas valve, and the cycle starts over.
If you selected the Automatic setting, the cycle continues until the clothes are dry, then the timer advances and turns the dryer off.
If you selected a timed setting, the cycle continues until the time has expired, then the timer turns off the dryer
Jul 27, 2009 | Dryers
Problem with Push to Start Button on my GE Gas Dryer
This dryer is under warranty. Call the store where you purchased it as they are obligated to fix it for free or take it back.
May 07, 2009 | General Electric DCVH640GJ Gas Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
New HE5t steam dryer will not turn on
What was wrong with your dryer? I am having that same problem?
Dec 27, 2008 | Kenmore Dryers
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
Whirlpool Electric Dryer stop working
could be a bad motor , or the starter on the motor.?? if you can hear the motor running then go for a new belt..
Jun 13, 2008 | Dryers
Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
Dryers Logo
132 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
