Question about Dell Dimension 2400 PC Desktop
Cd-rom drive door does not open - Dell Dimension 2400 PC Desktop
    Problem Solver:
  • 31 Answers
If you look carefully at the drive door, you would see one small hole. Put in one strong pin inside the hole and push the leaver inside. This will open the drive door.
Posted on Sep 05, 2010
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
CD in stuck in the computer and I can't get it out using the eject button. How do I get it to come out?
hi,
its too simple. you dont need to worry.. Check the front side of the CD ROM. you will find there one small hole. Now just take a thing, which is around the 4 to 6 inch (min is 4") long and can pass through that hole (for eg. take medium size U pin, and remove all bends and make it straight or long needle) Now insert this equipment in that hole and press. your ROM will eject...
Hope this has helped you ... Thanks....
Jul 19, 2010 | Computers & Internet
Cd rom door wont open
Do you see blinking light on your CD Drive. If not, you may need to check you power supply to CD Drive.
If yes, may be door looks jam, opening up once may remove any dust to smooth it out again. To open up there is small pin hole on cd drive, generally on the right side, use needle and press it through the pin hole, it will eject the CD Door and you can pull it out completely.
May 13, 2010 | Computers & Internet
CD Rom tray stuck
does the case a a faceplate infront of the cd rom drive(i.e. if there is a door that flops down when it opens)? if so you probably need to take off the computers faceplate and then you can get to the little hole.
Jun 14, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Cd rom drive door
Best guess is that a small plastic catch broke. My cousin has similar doors on his CD trays. I personally would take the doors off. As far as repair, again best guess without seeing it, is that you'll need a new door panel.
Feb 20, 2009 | HP GX613AA Pavilion A6300F Desktop PC
CD ROM
If the drive door sticks after you have used the paper clip to open it, look under the tray at the drive teeth (if any). Apply a liberalm coating of general purpose grease to the rwo inches of teeth at the end of the drive tray nearest you and close the drive door again. Open and close a few times to see if the door is now free. This worked for me on my Dell Inspiron 3100. Try it.
Jun 24, 2008 | Dell Computers & Internet
Cd rom door can't be opened
When U Insert A Pin Into the hole. does u feel that the pin is pressing some kind of pully? or anything?
if it
Jan 07, 2008 | LG (CRD-8400CB) CD-ROM Drive
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
The cd-rom door not open
Sir,
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
Dec 04, 2007 | LG (CRD-8400CB) CD-ROM Drive
CD Rom Driver door won't open without using the straightened out paper clip or pressing the driver door button upwards of 15, 20 or maybe 25 times. It will eventually open after repeatedly pressing for...
If this happens with all your CDs and everytime, I would suggest you should replace your CD Rom Drive with a new one. After use of some years CD Rom Drives have such problems. Otherwise a software might locking your drive. you should find a tool which unlocks the drive and then press the eject button.
Oct 06, 2007 | Acer Aspire M1640 Refurbished Intel...
Dell Dimension 2400 PC Desktop Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
