Question about HP P1100 21" CRT Monitor
Not coming on
When i turn on the monitor you can hear it swithing on and after 5 seconds it goes to standby mode.
  • Roy Henry May 12, 2008
    checked all that still nothing. I think it must be an electro mechanical fault
  • Anonymous May 12, 2008
    There is lock on the screen, I lost the book.
    Pheladi Maria Kola owner of TV.
    Problem Solver:
  • 11 Answers
Check your connection on your graphics.make sure you have activated your screen on control panel-display-advanced.
Posted on May 12, 2008
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
Acer p241w stays standby
Aug 31, 2017 | Acer P241W 24 inch Monitor
Hi, i have viewsonic 1940w. When i turn it on it makes buzzing sound and after 5-30 seconds it goes in stand by mode(orange light). Sometimes screen flickers to. If you turn off monitor and on again you...
I fixed this same Viewsonic problem by replacing the electrolytic caps on the power board and re-soldering the power transformer joints. The noise is coming from the transformer, if you torque it the noise stops. Cold solder joints must have been the cause (large posts did not heat up enough during construction). The bad joints might have caused a cap to overheat too, not sure but one was swollen and leaking and after replacing them the squealing was stronger and allowed a longer running time to locate the cold joint.
Oct 23, 2010 | Computers & Internet
MY harman kardon avr 21 swithes off about 5 sec after swithed on it goes to standby mode.
u have power supply problem. this is one problem u wont be able to solve by urself. get it fixed by an authorised tech or replace if warranty is valid.
Mar 14, 2010 | Audio Players & Recorders
Hi- we are having a problem with our just started overheating....we forgot to open the door...I heard the fan kick we turned off the ps3 to let it cool the ps3 is running...we...
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Intermittent lamp turn off
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
May 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
May 20, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
I'm still not sure about your question. Let me quess that by saying power/standy light goes to red...that mean your computer
is going into standby mode.!!!! So do it this way..on the left or right top corner of your notebook not the monitor, you should be having a small pin pointing up..I think that pin is use when you close the lid of your Laptop and it make your laptop goes into standby mode.When I mean goes into standby(sleep mode) the first think you can notice that your monitor light will be off and you can still see a very light image.So maybe this pin is stuck try to push it down for several times..
best of luck, takecare
Apr 19, 2008 | Computers & Internet
HP P1100 21" CRT Monitor Logo
57 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
