Question about Iomega HDD External Desktop (32660) 80 GB Hard Drive
The read write head of the hard drive won't stay over the disk to read. each time it goes over the disk it returns to its original position causing the clicking sound.
  • Iomega Master
  • 27,725 Answers
A dirty hard first clean all of the dust from your computer using a fine air blower from an air compressor making sure there is no moisture in the air line then give the hard drive a firm tap on one side to free up the read arm
hope this helps
Posted on Sep 05, 2010
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Hard drive won't read
can you see the drive ? if yes
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
Feb 24, 2012 | Maxtor One Touch II (EO1E200) 200 GB Hard...
Good Day! i have a aspire 6930. I've had it for a
The average life of a laptop is 5 years. Your model was made in 2008. Replace it.
Mar 01, 2017 | Acer Aspire 6930-6455 Notebook
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
I have a Fujitsu 80gb Sata hard Drive (2.5) which I have an adapter to use as a external Harddrive. However my computer and others only recognise it as a 14 gb drive. How do I get the full 80gb?
It seems this is caused by setting jumpers on your hard disk. Checkand return it to the correct position. Normally, your disk should be inthe position of Master or Slave.
Jan 16, 2011 | Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN...
My hard drive suddebly crash!!help
Why Disk Fragments a problem?
Any storage action on the magnetic disk like creating, deleting, moving, updating and copying files will lead to fragmentation and consequent performance loss. As time goes by, this accumulation of fragments on your hard disk becomes bigger and bigger. As the hard disk reads and merges these separate fragments every time you open a file, they will eventually cause problems such as system slowdowns, PC crashes, slow startup and shutdown, and will even shorten the life span of your hard drive. That is why defragmentation is so important for your entire computer system.
Advanced Defrag – The better and easier defrag solution!
You may find various defrag programs in the market, they may look the same, but many of them lack of ability to
effectively defrag all the MFT (Master File Table), they will automatically skip certain system files with extensions
such as DLL, INI, COM etc during the defragment thus left remnant fragments after each defragment action, it can
also easily get halted while defragging which is very user-unfriendly.
Advanced Defrag rectified all the cons above from these defragmenters, and the efficiency is even better. Its advanced
defragment arithmetic not only enables you to fast defrag, but also defrag completely and thoroughly. If you would
like to give your PC hard disk a completely care and experience the most efficient defrag technology, Advanced
Defrag is the perfect choice for you.
How it works?
Your hard disk controls a magnetic head which searches the areas where the parts of the required file are located,
reads the data and transfers these fragments to the disk cache or EMS memory. The time this takes is called the
average seek time. The average seek time of most hard drives is less than 9.5 millisecond. The Advanced Defrag
program is able to collect the various fragments of each file and store them very quickly into contiguous space on
the hard disk which greatly reduces the seek time of the magnetic head. Better file reading and writing speed is
provided as a result. It does make a difference if you have got used to work and play with a fast and smooth system.
It also helps to prevent premature hard drive problems and retrieve the data in the event of a drive crash.
Download Advanced Defra :http://www.versionhunter.com/windows/System/System_Miscellaneous/advanced-defrag.html
Dec 23, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
MHY2160BH Half dead wierd behaviour can't read / access data
If you have opened the hard drive case you quite likely have pooched the drive. This type of work is usually carried out in a proper "clean room" as even very small particles of dust that float around can cause destruction of a hard drive.
That is why they ALL carry a warning about opening them. some even have inert gases instead of air in them as an aid to keeping the inside clean and avoiding airborne corrosion.
Specialists are the only people I know who can dismantle and recover data from the platter but they are not cheap.
You are more than welcome to try yourself but you would need the EXACT control board right down to the revision number to stand even the slightest chance.
Aug 10, 2009 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Dropped external hdd 2.0 320gb now doesn't work, is getting power.
Hard Disks are generally VERY fragile, especially the external drives simply because the read/write head inside is a very tiny substance. your case suggests that when it dropped, the read/write head might have got broken, and which means....you might have to get a new one. BUT in a very rare case however..you can do a funny and pretty nice trick, just get another one of the same type (Exactly the same type), then get A Very Good Engineer, and tell him to help you to transfer the read/write head to the former one, just for the purpose of retriving your datas...then return everything back to its normal place. HE HAS TO BE VERY CAREFUL THOUGH!!!, so as not to damage the two hard disks!
(How I wish I could be there to fix it for you, cos I've done it A LOT before...lol).
Hope this solves your problem.
Jul 10, 2009 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
How is info stored on a floppy disk
This is how it works,
  1. The computer program passes an instruction to the computer hardware to write a data file on a floppy disk, which is very similar to a single platter in a hard disk drive except that it is spinning much slower, with far less capacity and slower access time.
  2. The computer hardware and the floppy-disk-drive controller start the motor in the diskette drive to spin the floppy disk.The disk has many concentric tracks on each side. Each track is divided into smaller segments called sectors, like slices of a pie.
  3. A second motor, called a stepper motorrotates a worm-gear shaft (a miniature version of the worm gear in a bench-top vise) in minute increments that match the spacing between tracks.The time it takes to get to the correct track is called "access time." This stepping action (partial revolutions) of the stepper motor moves the read/write heads like the jaws of a bench-top vise. The floppy-disk-drive electronics know how many steps the motor has to turn to move the read/write heads to the correct track.
  4. The read/write heads stop at the track. The read head checks the prewritten addresson the formatted diskette to be sure it is using the correct side of the diskette and is at the proper track. This operation is very similar to the way a record player automatically goes to a certain groove on a vinyl record.
  5. Before the data from the program is written to the diskette, an erase coil (on the same read/write head assembly) is energized to "clear" a wide, "clean slate" sector prior to writing the sector data with the write head. The erased sector is wider than the written sector -- this way, no signals from sectors in adjacent tracks will interfere with the sector in the track being written.
  6. The energized write head puts data on the diskette by magnetizing minute, iron, bar-magnet particles embedded in the diskette surface, very similar to the technology used in the mag stripe on the back of a credit card. The magnetized particles have their north and south poles oriented in such a way that their pattern may be detected and read on a subsequent read operation.
  7. The diskette stops spinning. The floppy disk drive waits for the next command.
On a typical floppy disk drive, the small indicator light stays on during all of the above operations.
and if i helped u solve ur problem in any way...please help me by clicking on the fixya rating..
thank you.
Mar 03, 2009 | Mad Dog Multimedia Dominator (MDED1F)...
Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
