Question about Dryers
Need to axcess burner to convert to LP gas. I have kit. How do I remove front cover? All screws behind door are removed. Samsung Model DV520AG
    President:
  • 3,074 Answers
There may be screws on the bottom corner, on the top corners you will need to pry with a flat tip screwdriver. These are clipped so it will pop off, then disconnect the dryer switch and the front panel is off. Good Luck Tim
Posted on Sep 05, 2010
I just purchased a GE frontload W/D set from a local chain retailer who didnt offer installation on the gas dryer that required conversion
Behind the knob on the control panel is a screw that needs to be removed to remove the control panel. Once removed, there is 4 screw around the door frame and two screw on the top of the front panel that needs to be removed to access the burner you seek. Converting to LP
Although this link if for a Whirlpool dryer, the burners and premise is the same. I hope this helps you, good luck.
Oct 10, 2013 | Dryers
How to do a lp conversion
Some basic helpful instructions below. Really not much to it. Convert the regulator and replace the orifice. Basic instructions should come with the kit if purchased for that specific brand and model.
In my opinion, always best to buy the conversion kit at a local appliance parts store to be sure of getting all the required parts with specific instructions for the brand and model.
Basic Step By Step Instructions:
First access the burner compartment. Usually a small access door in the lower right hand or left hand corner on some brands or models. Remove access panel.
On some brands and/or models the entire front panel must be removed. Look for screws in the door frame and/or at the base of the front panel. May have screws in both locations on some machines.
Some brands and/or models the top lid must first be lifted up wards. On many of these machines there will be no screws in the door frame. Usually only two screws are the base of the machine. Some no screws anywhere external. In this case, if there are two screws at the base remove them.
Then insert a thin blade or old credit card between the top lid and front panel about two or three inches in wards from each corner. Push in wards to release the clips while lifting up wards on the top lid. Each clip can be released separately or both at once.
Once the front panel is removed or access door is opened, look to the right of the gas control valve. There will be a tiny gas shut off valve on the gas supply pipe. Turn that tiny lever so it is across the pipe. Doing so turns off the gas to the control valve.
Than remove the wire quick disconnects from the solenoids on top of the gas valve. Than loosen and remove the hex nut on the control valve to separate the gas supply pipe from the control.
FYI:
That hex nut is reverse threaded. Which means the hex nut turns opposite (counter clock wise) to loosen it and clockwise to tighten it. Use a backup wrench to hold the pipe while turning that nut counter clock wise.
Once the pipe is removed, there will be two or more sheet metal screws holding down the plate the control is mounted onto. Remove those screws.
Than carefully remove the burner out enough to get to the wires attached to the flame sensor, which is attached to the burners shroud cover. Remove that wire quick disconnect also.
Than remove the entire burner as an assembly. Remove the brass or bronze orifice in the burners nozzle. Replace the orifice with an LP or NAT orifice to match the BTU rating of the burner.
BTU rating is on the manufacturers plate with the model and serial numbers, usually located in the door frame. Most dryers are either 18,000 or 22,000 Btu's. Install an LP or NAT orifice to match the rating.
Than convert the built into the gas valve regulator. By removing the cap on top of the tower and turning it over and reinstalling it. Cap should be marked "N" or "NAT" for natural gas and "L" or "LP" for propane.
Turning the towers cap over converts the regulator. Side of the cap facing you indicates the fuel type it is set for. Not all regulators are convertible in this manner. Check with any local appliance parts store.
Some gas control valves do not have regulators that are convertible while some have a set screw to turn to another position or a lever to turn to another position. Several variables are possible.
Appliance parts dealers are an excellent source for original replacement parts and conversion parts. Dealers are listed in the phone book under appliances.
Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks when reconnecting any of a gas part.
Use the reply button to add additional information or ask additional questions. Doing so will automatically move your question to the top of the forums list of questions.
DRYER SERVICE TIP:
It's always advisable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, connection and or repairs.
Nov 02, 2012 | Amana NGD7200TW Gas Dryer
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
Trying to mtake front panel off to convert from gas to lp
you need to remove the top cover by removing the screws out of the back,then remove the front control panel,then the front door panel and then the lower front access panel,all this needs to be removed to remove the gas line to the burner so you can take the burner tube out to change the gas orfice
Nov 18, 2010 | LG Dryers
Recently purchased Frig. gas stove.Want to convert from natural gas to Lp.Do you remove spud and insert Lp oriface in spud then screw spud back onto line?Lp oriface is a lot smaller than oriface for...
Not really sure which model you have but when converting the over, ether bake or broil burner you tighten down the orfice cap. If you remove the burner off the oven valve you will notice that you can put a wrench on the orfice cap. Just tighten snuggly. If you over tighten you will crush the orfice under the cap.
Dec 22, 2009 | Frigidaire Ovens
How to remove the front cover of my samsung front load gas dryer
take the top off first by removing the two screws in the back, then the five screws which hold down the door section. the door will lift off and then follow the instructions
Jun 08, 2009 | Samsung DV448AGE Gas Dryer
Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Whirlpool SF325 Gas Kitchen Range
How do you install an LP conversion kit on a Samsung dryer
kit comes with minimal instructions. you need to remove the burner which requires removal of the top panel, control panel and front panel. (see how do I remove front panel on samsung dryer for more details). It is fairly easy, maybe an hour the first time you have done it. Pay attention to all of the instructions re the burner, do not losen any of the gas tight fittings!
Jun 24, 2008 | Samsung Dryers
LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Dec 10, 2007 | Thermador PGR366 Gas Kitchen Range
Need to install LP converion kit How do I get to the inside of dryer
To convert a gas dryer to lpg. Undo door hinge screws, lift door and hinges, door should come off. opposite side of door opening remove 2 screws opposite form door hing side. Now the front panel will pull off front the top. Ease the top out and the bottom is just sat in two hooks and will lift out. Now your are in.
Nov 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
67 people viewed this question
Top Dryers Experts
