Question about Kodak ESP 5 Printer
Unable to detect paper edge - Kodak ESP 5 Printer
Plotter wont recognize edge of clear films when loaded from a roll or sheet. recognized plain paper fine
I would check the sensor on the carriage that detects paper. It might be dirty enough that printer cannot detect the subtle edge of the clear film. It is the blue light that turns on on the bottom of the carriage when you load paper.
Apr 18, 2015 | HP DesignJet 1050c plus InkJet Printer
T1100 unable to detect media edge. replaced line sensor, carriage PCA. Cannot calibrate line sensor. Panel reads calibrate sensor to black but does not print pattern and says "return error: 2".
I have seen this error occur when the carriage does not move smoothly left to right...are the shafts properly lubricated and the carriage belt in good shape (not frayed or teeth missing)?
Also there are special paper considerations for the calibration to work...Bright White Inkjet Paper is recommended., not just plain paper.
Sep 05, 2013 | HP Designjet T1100ps Printer
Kodak hero 5.1 cannot detect paper edge
Bought a Kodak Hero 5.1, full price, two weeks ago, spending an hour on each of our laptops and tablets to get them to talk to each other. Worked like a charm!
Then came the rain and the humidity and the message "Unable to detect paper edge" and two hours faffing around and fanning the paper (thx Blondepoison) and not taking a sledge hammer to the darned thing.
The shop will take it back in for "repairs" for ten days, but that's not the point, Kodak, is it?
Solutions: take it back to the shop and get another brand. Or wait two months for the dry season.
Jun 18, 2012 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 3250 Printer shows message "Unable to detect edge of paper" and paper just goes straight through
I've had this problem with my esp 3250 that has become progressively worse over past year. I have tried every fix available online from driver, cleaning, power, etc. My printers default quality was set to 'draft' (just to save ink) which obviously speeds up the printing and I've found that if I use 'normal' or 'best' quality, it seems to help the printer detect paper edges, I think bc it slows down physical printing process? go figure but it's gotten me around a few times when I've needed hard copies immediately. Also, changing to heavier bond paper, 92 or better helped with edge detection. I'll finish current ink and not buy another one of these:(
Jan 16, 2011 | Office Equipment & Supplies
Trying to change paper size from A4 to 8.5x11 on a Xerox Workcentre M123
  1. Pull out the paper tray.
  2. If necessary, slide the paper tray edge guides so that the guides are open.
    1. To adjust the side and rear guides, pinch the guide lever on each guide and slide the guides to their new position.
    2. To secure the guides in position, release the levers.
  3. Load the paper against the left-hand side of the paper tray. Paper can be loaded either short edge feed or long edge feed.
  4. If necessary, slide the paper edge guides so that they just touch the edge of the paper stack.
    NOTE: When loading standard size paper, set the edge guides onto the notches on the paper tray to match the paper size.
  5. Close the paper tray.
  6. Set the machine to detect the paper size automatically, or manually specify the required size.
    NOTE: Paper sizes detected by the machine vary depending on the Machine Administrator setting. See the Related Items below for additional information.
  7. If the type of paper has changed in the paper tray, then the paper type must be changed on the Control Panel as well. See the To modify the paper type on the Control Panel section below.
Normally just the guides need to be set correctly in the paper tray, The tray size sensing switched may be bad or the actuator on the tray may have slipped position.
Jul 22, 2010 | Xerox WorkCentre M123 Copier
PRINTER DOES NOT DETECT PAPER EDGE
Have you tried "fanning" the paper before loading it? This fixed my problem after a 6 hour battle, downloads of all firmware and restarting infinity times.
Apr 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
I put paper in align the guide, click on print. It doesn't print. It says it is unable to detect paper width.
Restart your printer,put 8.5X11 papers in th paper tray.Align the gray coloured paper tray to the edge of the paper.Place any paper on the scanner glass of the printer and press copy on the printer.You will get a copy from the printer. Keep posting me ...
Dec 14, 2009 | Kodak ESP 5 Printer
Printer Error "Failed to detect paper edge,.
Try upgrading your Firmware go to to this web www.kodak.com/go/5300downloads and look for firmware and download it, make sure that the printer is connected and turn on while downloading the firmware. thanks
Aug 11, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
MY ESP 5 PRINTER WILL NOT DETECT THE PAPERS EDGE.
Kodak printers support the following paper sizes: 3½ × 5 in. 4 × 6 in. 4 × 8 in. 4 × 12 in. 5 × 7 in. 6 × 9 in. 8 × 10 in. A4
Make sure that the grey coloured paper alignment is aligned properly to the edge of the paper.
turn your printer off and then turn it on again. put papers and align the paper alignment. try to print,your issue will be resolved.
Apr 04, 2009 | Kodak ESP 5 Printer
Kodak ESP 5 Printer Logo
405 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
