Question about Tissot Silent T Stainlesssteel Case and Bracelet sapphire crystal 30m water resistant men watch Watch for Men
My tissot silent-t watch looses time and will not set accurately. when setting either the minute or hour hand you must place your finger on the crystal 15 tickspast the desired location. the watch also will not let the hour hand pass under the minute hand most of the time.
SOURCE: tissot t touch, time problem
you need to calibrate it.
go to the '24h Cm' screen [T button, then touch centre screen few times]
hold down T button for 5secs
use + button to bring minute hand to 12 o clock position
use - button to bring hour hand to the same place
press centre of screen and it's done!
Phil
Posted on Aug 06, 2008
escapement
  • 2334 Answers
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Yes, pulling out crown prolongs battery life, but this is only for allmost unnoticeable period of time.
With the seconds hand there are only one solution- you have to take your watch to the nearest watchmaker as you will not be able to deal with it without appropriate knowledge and skills.
There can be two reasons why the seconds hand is jumping:
1) Fault within integrated circuit ( watch 'brain' is not giving an impulse in a specific period of time),
2) Few teeth may be damaged on second wheel as well as there can be tiny dirt particles sticking onto it.
Both need attention of professional.
If that seconds hand do not annoy you too much, wait till the watch needs battery replacement and then replace battery and check the watch at once. It will be cheaper then to do both jobs separately.
Posted on Dec 20, 2008
escapement
  • 2334 Answers
SOURCE: the digital time and the analog time are not synchronized
Here is complete manual for your watch:
http://www.t-touch.com/t-touch_images/usersmanual/140-en.pdf
If you are not successful with this, maybe it's time to change the battery?
Read manual carefully and you will find out how to recognize: I'ts time to change the battery.
Rate me, please.
Posted on Apr 04, 2009
OhioTrucker
  • 33 Answers
SOURCE: watch hour and minute hands are not lined up at 12 o'clock
Take the back off, then slip the works out of the case. move the hands to line up at 12.. hope this helps..
Posted on Feb 27, 2010
  • 5 Answers
SOURCE: the digital and hands display different times on my Tissot Touch
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Posted on Apr 26, 2010
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
Hi, there. I just purchased a Tissot PRC 17158652 from Amazon.com, brand new. It is running 10 minutes slow every hour. (I have only had this watch for 2 days). Should I return it? Or is there...
Amazon is the selling place for fakes. Take it to a local Tissot dealer or jeweler for verification. It sound like it says Tissot on the outside but says 'made in China on the inside. They will do that for you for no cost. Tissot are a great Swiss timepiece and should be accurate to a minute a month. If it is a Tissot, they calibrate using a gadget that listens to the ticks. They will keep it 24 hours.
My Chinese made Rolex gained 30 minutes a day. I see a pattern :>)
This one?
Tissot Men PRC 200 Chronograph Watch Black T17 1 586 52
STOP FAKE CHECK ONLINE RETAILER
How to Spot Fake Tissot Watch
fake or real tissot Google Search
Fake Tissot prc 200 mens swiss watch How to spot chinese fake
Oct 28, 2017 | Watches
Hello, I have a Tissot Veloci-T watch, purchased about 10 days ago, and I'm not sure if there is a mechanical problem or just merely a battery issue. The hour and minute hands do not sync up on...
The list of problems is impressive and if you still have the proof of purchase, it should go back to Tissot for repair or replacement. It shouldn't matter where you bought it, so long as you can prove that it is within the warranty period.
(It sounds as though it has been dropped onto a hard surface)
If you haven't got any proof of purchase, then you will have to pay for any repairs.
May 08, 2011 | Tissot T0244171705100 Velocit Watch for...
Setting my Tissot touch Navigator 3000
Per the manual: http://support.tissot.ch/usersmanual/140-en.pdf
When your battery begins to die, the hands are no longer synced.
After replacing the battery, go into local time mode (pressing the center of the crystal) until "Set" appears. Press the crown. Scroll to "ECO BAT", press and hold the crown for 5 seconds until "SYNCHRO" appears. Use the "+" button to move the minute hand and the "-" to move the hour hand until they are in the upright or 12:00 position.
Either press the crown again or wait until the watch automatically leaves the Set mode. Your hands should now represent the local time.
Feb 08, 2010 | Tissot T Touch Navigator 3000 T96.1.478.32...
How do I change the time on the tissot 1853 touch watch
  1. Locate the screw on the side of the watch face. This screw is what you will use to set the time on your watch. Water-resistant watches have a screw-type crown, and the screw must be turned toward the body (unscrewed) before it can be pulled out for further use. If the watch is not water-resistant, the unscrewing is unnecessary.
  2. 2 Pull the screw gently outward. The screw can be pulled outward in two positions. The first position sets the date and day. Pull the screw out farther (into the second position) to set the time.
  3. 3 Turn the screw either clockwise or counterclockwise to move the minute and hour hands to the desired time. Push the screw all the way in (and turn it away from the body if you have the water-resistant model) when you are finished.
    Digital Watch
  4. 1 Locate the three buttons on the side of the watch face. These are the buttons used to set the time. The top button is the "+" indicator for increasing the numbers. The bottom button is the "-" indicator for decreasing numbers. The center button is to activate the setting mode.
  5. 2 Press the center button in for one second. The watch will beep.
  6. 3 Press the top "+" button for two seconds. After the watch beeps, you can begin setting the time.
  7. 4 Press either the "+" button or the "-" button (depending on whether you want to increase or decrease the numbers) to set the time.
  8. 5 Press the center button when you are finished. The watch will beep. This validates the setting. The seconds will revert to zero.
Read more: How to Change the Time on Tissot Watches ' eHow.com http://www.ehow.com/how_5934972_change-time-tissot-watches.html#ixzz14ifvni46
Nov 04, 2009 | Tissot T-Touch T33159851 Wrist Watch
Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
Sep 22, 2009 | Tissot T-Touch T33159851 Wrist Watch
My tissot toch hour and minutes are out of sync for instance at 10:45 it appears like the hour is on or past 11. Is their any way to re-sync them or reset them.
This is an expected, needed adjustment, and is addressed in the manual:
http://www.tissot.ch/data/usersmanual/138-en.pdf
Syncronisation
Sep 11, 2009 | Tissot T-Touch T33759851
Date function notworking properly
Do as follows:
1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Apr 04, 2009 | Tissot Le Locle T41.1.423.33 Watch for Men
Tissot t touch, time problem
Phil
Jun 29, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot t touch
there are sync instruction on the manual page on the web.
Jan 12, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot Silent T Stainlesssteel Case and Bracelet sapphire crystal 30m water resistant men watch Watch for Men Logo
337 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
