Question about Averatec (E33-0700010-S69) Cooling Fan
Fan does not run. computer says cpu fan failure.
  • 61 Answers
First check the connector and that is good then fan has failed. You can get a new fan from places like Computer Geeks dot com or Tiger Direct. Make sure you get the right fan for your CPU.
Posted on Sep 05, 2010
My vostro 200 encountered cpu fan failure but i use it then it shots down and never runs it again what should i do???
Hi, its not a good practice to use a pc without a CPU fan. most cases the fans pc shuts down to prevent damage to the CPU. i will advance you take it to a technician to have the fan replaced. then it will work if the CPU has not already been damaged by you trying to use it without the fan. but i am sure that is not the case. get the fan changed and you pc will work again
Oct 16, 2012 | Dell Vostro 200 Desktop Computer
Fan failure from the start..power failure
open your cpu check whether your fan running or not, if it run mean , go to bios and disable the alert so that you can log in to your OS.
If fan not run mean
Open up the case, check the CPU heatsink fan is connected to the motherboard, if it is try booting up with the side panel still off, does the fan spin up?
Check it, good luck
Jan 11, 2011 | ASUS P4S800 Motherboard
I changed my cpu fan out, when i started it up it ran 30sec and shut down. So i replaced new mother board without fan., it still shuts down after a few sec. I disconected the 4 pin power source and it will...
From your problem description it sounds like the CPU was overheated (and failed) before you replaced the CPU fan - so the fan replacement was too late. Since the procesor already failed, installing a new motherboard without a fan did not accomplish anything.
The 4 pin power plug provides +12 volts DC to the processor. When you disconnected it, the processor essentially could not run at all and the system is no longer capable of detecting the CPU failure and shutting down the power supply.
You need to install a known good CPU which is the right type and speed for your computer. Unless you are experienced in replacing,CPU's, fans, heat-sinks and applying thermal grease I recommend that you have a PC technician perform these tasks.
If you believe that this information is of value to you please rate me on the FixYa website.
Regards,
Yavacotech
Nov 29, 2010 | Computers & Internet
ASUS Motherboard M2N68-LA (False) "cpu fan has failed" If I press the F2 on the keyboard, bypass this failure and computer keep running well.
U'L LDAMAGE YOUR MOTHERBOARD AND THE CPU TURN IT OFF AND UNPLUG ALL CABLES OPEN THE CAS COVER AND CHECK THE CPU FA N IS MOVING OR NOT IF NOT THEN CLEAN THE FAN AND CHECK THE FAN CABLE IF IT STILL NOT MOVING CHANGE THE HEATSINK INCLUDIN THE FAN DA VN
Jun 13, 2010 | Intel D915GAG Socket 775 Motherboard -...
All computer fans starts ok but trips with notice,
You may hear the case fans running. Remove PC cover and check CPU fan and replace, it may not be running at full speed.
Sep 23, 2009 | HP Compaq d530 SFF PC Desktop
I have fan failure. It has been making a strange
This is probably because the fan has most likely 'died'. I would replace the fan because you don't what your computer to start to freeze up, overheat etc...
Jul 10, 2009 | Dell XPS 200 PC Desktop
Computer keeps shutting down.
Do the fan's spin when you power the PC on? All of the fans should spin up for at least a second upon initial boot. The CPU fan and video fan (if you have an external card) will spin the entire time the PC is on and vary in speed depending on temperature.
Try booting the PC with the side of the case off and note and fans that aren't spinning. The temperature to shut off the CPU is really high. If the temperature is getting hot enough to do this, you should notice a failure in a fan right away.
Mar 09, 2009 | Computers & Internet
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mike
Mar 24, 2008 | Computers & Internet
CPU fan failure
The bearings in the fan or internal mechanism may have burned out. If the fan does not generate a cool enough environment, you run the risk of frying the processor and other motherboard components that are temperture sensitive.
Replace, don't attempt to repair.
Keep me posted.
Oct 27, 2007 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
