We are getting color separation on the entire screen, and a concave distortion at the bottom of the screen. The tv is about 10 yrs old, so if it's a relatively cheap fix, we'll keep it.
  • cranwill Sep 07, 2010
    Sorry, its a Mitsubishi HD1080, about 10 years old.
  • 5,807 Answers
Thanks for choosing Fixya for assistance in advance!
I would like to know model and make of your TV?
On some TV, these is done through the Original remote
in conjunction after checking the components on the
Pincushion and Convergence Circuits.( Auto focus )
Should you feel you can DIY and have the tools and
equipment I can guide you where to look at .
and the possible components to check.
On some it is a cold solder joint but a visual and
actual check may confirm these.
These circuits are usually connected with the Vertical
and Horizontal Circuits which employs horizontal
output Transistors that is connected to the
Flyback
I will post more once i know the
make and model of your unit to help you.
Posted on Sep 05, 2010
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
RCA-picture discolors, goes concaved
Sounds like a capacitor in the power supply is beginning to fail.Unless your good at this type of repair, I would call a tech to have it serviced. And I would also not use the set until the problem is corrected, or it could get real expensive to fix.
Feb 02, 2009 | RCA HD52W58 52" TV
Sony Trintron KV-36HS500 TV color distortion
Sounds like the set is out of degausing, you will need someoen with a degausing coil to come and fix it. Should take all of 10 seconds and cost $100 or less. Let me know if you need more help.
Tim
Sep 11, 2008 | Televison & Video
Concave TV screen
your tv needs to be looked at by a professional tech..it may need reconverged..
Jul 27, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Sony 52XBR Rear Projection
Sounds like some kinda convergence problem. Can you post an image please?
Jul 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence problem
The convergence ICs are located on the left board on a huge heatsink they should be STK392-110 or STK392-120. You can get replacement ICs at the following link and they also provide free step by step instructions on how to remove and install the new ICs.
http://servicemanuals.vstore.ca/
Mar 29, 2008 | Philips 60PP9202 60" Rear Projection...
Concave distortion on top and bottom of screen
Bad convergence IC's ....change both for reliability...part number
STK392-570...located on center PC board.................T.
Feb 11, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
