Question about GE DBLR333EE Electric Dryer
Model No.BBL333EB1WW My dryer is not heating what should i do?
    President:
  • 3,072 Answers
Check the heating coil which is located inside the dryers' right rear corner. Unplug dryer, open door, remove all screws, pry on top corners with a flat tip screwdriver, disconnect dryer switch, set panel off to the side, lift up on top lid and check to make sure coil is not burnt in half. Hope this helped tim
Posted on Sep 05, 2010
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
Whirlpool electric dryer high thermostat replacement
test all this steps in according with your model, electric or gas. God bless you
Thermal Fuse
Gas Valve Solenoid
Dryer Igniter
Heating Element
Flame Sensor
Cycling Thermostat
Main Control Board
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer.
Jul 21, 2013 | Dryers
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
Dryer will turn on and count down but will not start to spin or heat up, model med6600tqo
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 28, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Model #w8w2780wcwww over and under. dryer works but does not heat. ge model
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | GE Dryers
Hello i have a Frigidaire Gas Dryer model # CGR3600A53 it is not heating at all. how much is the heating element for this model and is the repair that tough?
check out this electric no heat tip...
heatman101
Jun 25, 2010 | Frigidaire FGQ332ES Gas Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
GE DBLR333EE Electric Dryer Logo
48 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
