Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I am trying to us this router with my laptop and I have model #DI - 524. I need a manual to set it up. The router is a D-Link 802.11g/2.4Hz, Model DI-524
  • 61 Answers
Hxxp://www.retrevo.com/support/D-link-DI-524-Wireless-Routers-manual/id/420ci365/t/2/
Check to see if this is the correct model. If so, change the "x"s to "h" in the link. Not sure if I can post live links here.
Posted on Sep 05, 2010
DOCUMENTATION DISCRIBING THE ROUTER MODEL FETATURE OF THE D-LINK di -524
Here is the user manual (PDF):
http://www.dlink.com/-/media/Consumer_Products/DWL/DWL%20922/Manual/DWL922_Manual_EN_UK.pdf
Feb 15, 2014 | D-Link AirPlus DI-524 Wireless Router
How to i setup this router "D-link DI-524
Link to router information, you need to select your model revision, then you will be able to download your installation guide, firmware updates, etc
ttp://www.dlink.com/products/default.aspx?pid=DI-524&tab=3
Mar 04, 2011 | D-Link AirPlus DI-524 Wireless Router
Forgot my DI 524 setup password, pushed RESET button, what next?
You will need to login as admin and set it up again. Connect per ethernet cable, open a browser and enter 192.168.0.1 You should see a router welcome screen or logon dialog login as admin the default password maybe one of several things depending on the particular revision/edition blank/null 'admin' 'password'
Support for this model is available at http://www.dlink.com/products/?pid=DI-524&tab=3 manual at ftp://ftp.dlink.com/Gateway/di524/Manual/DI-524_manual_06292005.zip
Once you're in you will have to set up an ISP connection which may require your ISP username / password and selecting a protocol particular to your ISP and setting up the wireless WEP key
Jan 08, 2011 | D-Link AirPlus DI-524 Wireless Router
I have router DI-524 and am unable to connect to internet thru this router. But it says, it is connected
I would do a hard reset by pushing the small button on the back. You will need a small pen to push it. Push and hold down button till the lights flash I would/ say 10-15 seconds should be good enough. Once it's reset try setting up all of your settings again. Remember if you have dsl you will need you username and password to be inputed in some cases. If it is broadband most likely you will not have to bother with username and pass hope this helps.
Nov 30, 2009 | D-Link AirPlus DI-524 Wireless Router
I have a d-link model DI-524 that stopped working for my laptop I try to connect but is saying it cannot recognize the dns
Let's try to first fully reset your router to factory settings to see if we can get rid of any bad settings that may be causing issues. I borrowed all of the following from the technicallyeasy.net walkthroughs already written about:
To reset your router, use the following steps:
  1. Press the reset button for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. (Added by me) Plug your laptop directly into one of the ethernet ports on the back of the router with a standard CAT5e or CAT6 patch cable
  4. Open up your Web browser and enter 192.168.0.1 in the address bar.
  5. For the login, enter admin as the ID and leave the password blank.
The router has now been reset. Follow the steps in Securing D-Link DI-524 Wireless Router to secure your router.
SummaryThis post has provided the instructions you can use to reset your D-Link DI-524 wireless router. If you are having problems with your router, try reseting the router to the factory defaults, and then make the changes again and see if the router starts working."
Nov 15, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Forgotten key to access my secure d-link wireless router model
hey what you can do is you can reset the entire router... by using the reset button on your D-Link router... Or else you can also access the router by using the following IP address in the internet exlorer...
try 192.168.1.1 or 192.168.1.0 & then go to the wep settings & reset the router or change the password for the router...
Jan 18, 2009 | D-Link AirPlus DI-524 Wireless Router
I cannot connect to my router via the IP in the browser
Check first the cables and connections, and the broadband filter.
You need to connect through cable to configure the router.
To access the router panel you need to input the router IP address on Internet explorer bar.
default IP is http://192.168.0.1
If IP is not default, you find out IP by opening the command prompt from start menu>>all programs>>accessories>>system tools (that kind of dos mode). On command prompt type ipconfig/all.
The default gateway is router IP.
On the router access panel default settings are :
User Admin
Password leave blank
See all procedures on manual below.
Copy and paste the address below on your browser address bar.
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
Dec 08, 2008 | D-Link AirPlus DI-524 Wireless Router
Drivers for DI-524 Wireless Rourter D-Link
You can find donwload here:
http://support.dlink.com/products/revision.asp
follow the instruction.
me this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 21, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
168 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
