My tv LG 47LB5D FU takes about 5 minutes to see picture. It pops off and on several times before it stays on and I can get a picture. Wondering if this a with the power board?
  • 17,129 Answers
It is possible that the main board is having a dry soldering on the board which can be traced to the section where you are possibliby noticng some heating.
Open the panel and tap on the boarrd lightly to see if there is any change on the section. .Remove to see the solder joints and use a good iron to solder with fresh solder.
Secondly there can weakness of capcitors in the Power supply as this might reduce the +B and create this shunting action to come forth. So take a quicck look and change suspected capacitors if the +B voltage is low.
Finally check onthe driver section for any capacitors seen weak. The solderring in this section must be looked into carefully.
Posted on Sep 05, 2010
LG 47LB5D TV just turn off by it's self after about 10 to 15 minutes let it cool down turn it back on it last about 10 to 15 minutes again. all the capacitors all look good
Capacitors can fail without any outward signs. You need to use a thermal scanner or freeze spray to see what is getting hot.
Feb 26, 2016 | LG Televison & Video
No sound coming from LG TV 47LB5D
Are you able to hear sound from the head phone socket, if it has one? Do you get sound when you are playing a DVD player? Is any mute button is activated or jammed?
Aug 21, 2012 | LG 47LB5D Television
My LG 47LB5D will come on and has sound, but.....
can you post a picture or email one to customerservice@tvrepairworld.com and they can let you know whats causing the issue. It could be a flex tab bond or possible LVDS cable or Tcon
Aug 04, 2012 | LG 47LB5D Television
I have an LG 47LB5D LCD Tv that shuts off after approximately 30 minutes running time. It will cycle back on after a few minutes, so I assumed it was the power control board; replaced it but Tv still shuts...
It sounds as if the resistors on the board of the television are shot not much that can be done but replace all of the boards in the television you should try and aim fans into the vents on the television and see if its stays on for longer
Mar 05, 2011 | LG 47LB5D Television
LG 47LB5D - When TV is turned on green light flash a few times and screen comes on but input is not recognized. TV is unresponsive to all commands. TV will not turn off unless power button on TV is held...
There's no quick fix on your problem because you hava a leaky electrolytic on the supply of the microcontroller.Leaky capacitor affect the regulation of b+ and sometimes works within warms-up but the sympton will get worst. I've rather suggest you to send it to repair shop to isolate the problem because the microcontroller itself is one of the major suspect on this case.
Thanks for using fixya.
Pls rate my help.
Jan 21, 2011 | LG 47LB5D Television
LG 37LC2D will not turn on
mine just did this tonight as well.... no answers yet?
May 09, 2010 | LG DU-37LZ30 37 in. LCD HDTV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
