Question about Surebonder Pneumatic Stapler
Looking for owners manual for spenax sc661 hog ring gun
How do i replace the cushion in a buick lacrosse 2008
You have to remove the seat from the car, turn it over, and cut/remove all hog-rings holding the cover to the seat and pull the cover and cushion off. Set the new cushion in the cover, place it back on the seat frame, and hog-ring it back in place at the same points the original hog-rings were. Put the seat back in the car.
Nov 13, 2017 | Buick Cars & Trucks
When was gun made ,serial number
Gun control act started in 1968 so the US federal law to regulate the firearms industry and firearms owners
Apr 21, 2014 | Remington Shotgun Mount 12Ga Lh, B Square...
My heating seat stopped working in my 2000 yukon denali
You have a broken wire in the seat. The blue wire inside the seat cushion will break or burn in two. If you are handy with tools you can remove the seat, remove the screws from the control switches cut the hog nose ring clips, undo the velcro on the back of the seat bottom and carefully remove the bottom seat cover. You will find that the blue heating element blue wire in burned in two. Cut the bad part out, slide some heat shrink tape over one end. Slide it far enough so that you wont shrink it from the solder gun. Solder the two wires together and keep the joint minimal so that the shrink tape will slide over the solder joint. shrink the tape with a heat gun or hair dryer.Put everything back in reverse order. You will need to go to an older conventional auto parts store and buy a hog nose ring kit with the pliars to replace the upholstery. Go to an upholstery shop and they can tell you where to buy it . It should cost 3 or 4 dollars. this whole seat repair should not cost over $8.00. Also remember check the fuses first and also remember that the seatbelt has to be fastened for the seat heater to work.
Jan 08, 2013 | 2000 GMC Yukon Denali
Would a Remington nylon 66 be a good ground hog hunting gun
It should be as long as you're not planning to take one from more than 30-50 yards. As I recall it had pretty high grades for accuracy.
Jun 27, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
Every time i hook up the co2 tank the air sprays out from the inner body body of it. around the power tube and valve i think? i guess the airlock isnt working but i dont know what part? can u help??
Look at the "Tombstone". This is where the air comes up to the gun from the
bottle. There is an O-ring that is supposed to be toward the trigger side of the tube and many
times they fall out and there is no seal. You may need to buy an O-ring kit and replace the O-rings to fix the problem.
Here is your owners manual and diagram. I own 2 of these and after a few times
taking them apart it will be second nature.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Feb 23, 2011 | Tippmann A 5 Standard Paintball Gun
I am trying to find a manual for a binks 2001 spray gun i am having trouble figuring out where the o ring number 7 goes
I looked up same gun. I think I googled "binks model 2001 spray gun" and I got a pdf with all info and diagrams. On the available websites, I looked for the one that looked like official Binks site.
The PDF # I got is 77-2316R-14.pdf. It shows that #7 o ring
Nov 05, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
McCulloch FH160G Pressure washer has a weak spray. Unable to locate my owners manual.
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FH160G-6096160G04-966989801.pdf your owners manual. Most likely the gun needs replacement or you can take it apart and replace the necessary o rings. These are common issues with this type of pressure washer.
Apr 21, 2010 | McCulloch FH160G Pressure Washer
McCulloch FH160G has weak spray
There isn't much in the owners manual in the way of repairing this issue, asside from just replacing the gun. Most of the time it's as simple as an o ring, but because of their design it's easier just to replace the gun. But here's a link. http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FH160G-6096160G04-966989801.pdf
Apr 21, 2010 | McCulloch 1400 Psi Electric Pressure...
Removing seat covers on 2000 Jeep Wrangler Sahara
The seat covers are held on by "hog rings" They are steel rings that are clamped around the metal wires. You will need to use cutters to take them off. When you get ready to reinstall new covers, you will have to get a set of hog ring pliers, and some hog rings.
Mar 26, 2009 | 2000 Jeep Wrangler
How to reassemble a crosman 357.177 pellet gun.
Just visit Crosman's website and follow the link down at the bottom for the owner's manual. When you scroll down to the 357, there will be an exploded parts diagram. It's a it of a puzzle to put it back together, but I got mine back together. Just be prepared to replace the o-rings. I destroyed mine taing the gun apart.
Mar 25, 2009 | Crosman (4032)
Surebonder Pneumatic Stapler Logo
98 people viewed this question
Top Surebonder Tools & Hardware - Others Experts
J D Wright
Jo Ann
Level 1 Expert
Are you a Surebonder Tool and Hardware - Other Expert? Answer questions, earn points and help others
