Question about Homedics Health & Beauty
Blood pressure cuff will not register blood pressure. It displays "EE". Please give address and instructions to return monitor. (batteries are new)
  • 4 Answers
SOURCE: Only blood pressure result I get is 'EE'
That either means you are moving, or you are inflating the cuff to soon after turning it on. Either of these is what mine means when I use it.
Posted on Jan 19, 2009
Max J
  • 22 Answers
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
DrRonJupiter
  • 10 Answers
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com 30ad4e8.jpg
Posted on Oct 13, 2009
SEGlover
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
  • 4736 Answers
SOURCE: my homedics model 518732 blood
In this case, you need to contact HoMedics Customer Support 800-466-3342. Have the Model Number handy when you call. Monday - Friday 8:30a - 5p ET.
Hope this helps you. Please let me know.
Posted on May 16, 2011
Cuff inflates way too much..registers EE error
See page 14, it can also be underinflated which is more likely. It depends whether the EEs are next to each other or on top of each other. The inflated cuff has to cut off the blood supply, and then it measures when the flow starts to come back.
It is a manual inflation model if you are in the right category.
http://omronhealthcare.com/wp-content/uploads/hem-432c.pdf
May 08, 2016 | Omron hem-432c manual arm digital blood...
What does ee mean on the omron blood pressure monitor/HEM-731C?
is it a 780 or a 731? found manual for 780; http://omronhealthcare.com/wp-content/uploads/hem-780-instruction-manual.pdf nothing on 731. Try removing the battery for 10 min to reset all. May be time to replace.
May 02, 2014 | Omron HEM 780 Automatic Blood Pressure...
Error code EE or E
Check your user manual, there should be a section on error codes. Most often E or EE errors are leaking cuff or improper use.
Aug 16, 2013 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Ee 16
http://manuals.harborfreight.com/manuals/67000-67999/67212.pdf
Jul 25, 2013 | Oregon Scientific Wrist Blood Pressure...
Lately when trying to get blood pressure "EE"
The EE symbol can mean one of three things: Excessive low blood pressure, improperly placed cuff or movement of the arm during the measurement.
Hope this helps solve the problem. If it continues, contact HoMedics Customer Service @ 800-466-3342
Mar 22, 2011 | Homedics Automatic Arm Blood Pressure...
I have a cuff like this and get an error saying EE
According to the Owners Manual, the EE Message shown on the display or the blood pressure value is displayed when an excessively low (or high) reading is detected OR as a result of one of the following:
1. Cuff has been placed incorrectly. Solution: Wrap cuff properly so that it's positioned correct.
2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady at heart level during measurement.
3. Shaking or moving of the wrist with the cuff on. Solution: Same as # 2.
NOTE: Be sure the cuff is placed exactly as pictured on the face of the box, 1/2" above the heel of the hand.
Jan 27, 2011 | Walgreens By HoMedics Automatic Wrist...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Jan 18, 2009 | Omron Auto Bp Monitor with Easy Wrap Cuff...
Health & Beauty Logo
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
