Question about Dryers
How do i change the door to my whirlpool dryer
    President:
  • 3,074 Answers
You will have to remove the front panel, to do so unplug dryer, open door and remove all screws, with a flat tip screwdriver gently pry up on the top corners, the pull panel forward and disconnect door switch, then look at the back of panel and remove old door and replace. Hope this helped tim
Posted on Sep 05, 2010
How do u open a whirlpool dryer door to change the switch?
Door switch has to be replaced since it is defective. Disconnect unit from main source of power and get to it.
Jun 14, 2016 | Whirlpool Dryers
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool duet dryer lock is loose
You have to change the plastic catches there are 2 one on the top and one on the bottow of the door
Jan 14, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool doet washing machine
the door on any frontload whirlpool washer cannot be changed from side to side.only the dryer
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 9250 frontload
As far as I know, this door is NOT designed to be reversible. It is designed to open the opposite way of the matching washer to make it easier for you to move clothes from one to the other.
Mar 27, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer
try this at your own risk lol set the timer open the door hold down the door switch and give the tub a hard spin with your hand clockwise see if it starts if it does the switch in the motor is bad and you will need to replace or clean the motor
Feb 11, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
