Question about Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A
Describe your Problem i have a quasar vulcan gas heater pilot light is on but wont ignite. can hear it clicking trying to ignite what is the o=problem . this heater maybe about 20 years old
    Problem Solver:
  • 5 Answers
What do you mean by the pilot light is on but won't light. Do you mean that there is gasbut won't light. If so the spark may not be hitting the pilot properly or it may not be getting enough gas. If lighting but continuing to spark the sensor may need cleaning. This can be cleaned with steel wool (not sand paper), probably will need to disassemble the pilot asembly The pilot may also be dirty reducing gas flow. If this is the case dis-assembly will be needed and the pilot cleaned.
Posted on Sep 05, 2010
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Vulcan wall heater gas issues...
The igniter may be bad and needs replacing.
Jul 01, 2017 | Vulcan Heating & Cooling
Vulcan express gas continuous flow/model # 230010N0/serial # 66669/ Date 19-08-98. I can hear and smell gas when trying to ignite the pilot light and the igniter spark, "sparks", but pilot light...
VULCAN water heater continnous model number 23001ono. im looking for a brass nut that sits on with a very small hole, with a number on it (25)
Mar 10, 2011 | Heating & Cooling
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Old vulcan heater pilot light on but will not ignite heater when you turn it on please need help ..thank you
I believe that model has a milivolt pilot generator. The possible causes of your problem could be a dirty pilot generator preventing it from providing the proper voltage to the gas valve or a defective gas valve. If you have a digital multimeter that will read mili volts, you can check the out put of the pilot by placing the leads on the two wires at the gas valve and reading the voltage. It should be 500-750 mili-volts. One other possibility could be one of the safeties have opened. They will be little button type snap disc limits with a button on the top. They will have a wire connected to each side. Push the button, if you hear a click, that safety has tripped. If you provide the exact model number I can post an exploded view for your use.
Sep 15, 2009 | Heating & Cooling
Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Aug 23, 2008 | Heating & Cooling
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Open Questions:
See all Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A Questions
Heating & Cooling Logo
353 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
