Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
The LCD screen doesn't respond to my touch. It's stuck on the date/time screen
  • 76 Answers
Sounds like a bad lcd panel assy or the lcd cable. The unit needs to be serviced for a 100% diagnosis but it will be one of those 2. I hope this helps.
Posted on Sep 06, 2010
  • 67 Answers
Hi
this is lcd cable problem
1)you need new lcd cable for replace,
2)open your camera body carefully you will see slim cable between circuit board and camera body,
3)now see properly wining of cable , replace old one with new one
you just done>>>>>>>
the pic is for refrance only there is different for every model
Posted on May 28, 2011
4 Suggested Answers
sonyfsd
  • 161 Answers
SOURCE: I reset my Sony DCR-HC21 and now the LCD screen doesn't respond
there is a problum in side the camera one is ffc whicis connect the lcd to main board if no then lcd it self having problum because thes tuch switches are in side the lcd please go to your nearst sony service centre & fix this problum
Posted on Apr 29, 2010
Rick Riggins
  • 1812 Answers
SOURCE: LCD screen doesn't respond.
The LCD / Touchscreen module is no longer available from Sony for this Model. However, I have a limited supply of them as well as an aftermarket supplier.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Jul 30, 2011
SOURCE: LCD screen is not reacting on touches. The camara
What does replacing the flex cable cost to replace?
Posted on Aug 23, 2011
Why does LCD screen not respond to touch
Common problem. There is a flexible cable that goes from inside the body to the flip out LCD screen. More than likely, this cable needs to be replaced. Time for Professional service. We can help!
Contact Us at AVRepair com
Jul 10, 2014 | Sony Handycam DCR-DVD505 DVD Camcorder
Touch screen doesn t work
The touch screen connects to a control board. Regardless of what the diagnostics indicate, the control board may be defective.
Jan 16, 2014 | GE Dryers
Touch screen not working
The same thing happened to mine all you have to do is unplug you're car battery then plug it back up then it should work but first u have to calibrate before it works should calibrate very fast
Feb 15, 2013 | Soundstream VR-738NB 7-Inch Lcd...
Setting the date and time
After selecting 1, type in the date mm/dd/yy (it doesn't appear on the screen) then press hold/save. Then type in the time again it won't appear on the screen press hold/save. It will then return to the main screen with the correct time and date. Hope this helps.
Oct 16, 2012 | LG Ericsson LIP-8012D 12 Button IP Phone
I reset my Sony DCR-HC21 and now the LCD screen doesn't respond to my touch. It's just stuck on the date/time screen. I tried to do the calibration, per the user manuel, but I can't get to the calibration...
Apr 29, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
Samsung m8800 my touch screen doesn`t work ...it hangs or get stuck sometimes ..what is the reason and got some solution for that or ..it`s just the software that has been made to hang after finishing it`s...
It is a hardware problem in this set... after some time, your screen will stop responding at all... there is one solution I found on the internet...
just follow this link
http://www.handcellphone.com/mobile/forum/screen-freeze
mine is working now
But try it at your own risk
Mar 29, 2010 | Samsung SGH-E840 Smartphone
Lcd problm
there is 2 types of fault for this....one lcd cable damage or touch panel damage if it is you have replace LCD
Feb 27, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
IPaq rx3115 screen unresponsive
Bad screen if the driver was bad they would tell you that you are having a problem with the driver
Feb 07, 2009 | HP iPAQ RX3115 Pocket PC
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
649 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
