Question about Car Audio & Video
My MTX JACKHAMMER 1200 amp keeps blinking yellow light and amp won't power on.
4 Suggested Answers
SOURCE: No LED power lights go on
the light with the power light(middle) is a blue/purple faint light try checking it out at night.The squiggy(as heat waves) will only light when the amps shuts down due to thermal protection(wait for it to cool). The bolt/yellow (short circuit) will light when there is an electrical overload in any of the wires(check +ve leads).
Posted on Jun 21, 2009
SOURCE: Apx stopped working, MTX 702x
maybe the audio amplifiers Ic´s damaged or the power fet
Posted on Mar 06, 2009
  • 155 Answers
SOURCE: my sony xplod 1200 whatt amps red light keeps comi...
check your ohm load on the sub and see if your amp can do the same, That is why every time it shuts off into protection mode. Check your gain level on the amp to this is not a volume knob for your amp, It is to get both the amp and cd player on the same page. Hope this was helpfull
Posted on May 27, 2010
Mtxjh1200 , the light with the lightning bolt blinks and subs make a thumping sound like a heartbeat
ur rca wires or its the holder itself if the subs do it when the rca wirtes are off the oits the bord inside the amp
Jun 21, 2011 | MTX JackHammer JH1200 Car Amp
Hi i have a mtx jackhammer JH202 amp and a mtx jackhammer jJH5510D sub and every so often when a song is playing there will be bass and al of a sudden it will shut off and after a few minutes it will come...
The problem was caused by you trying to run a 2OHM load on an amplifier which is designed to run only on 4OHM when it is bridged, the amplifier is most definatley cooked. An authorized MTX technician should take a look at it, to determine just how wide spread the damage is.
dreamsystems.
Feb 11, 2011 | MTX JackHammer JH202 Car Audio Amplifier
It wont turn on, it give me a flashing light on the flash sign..
please run a thicker power and ground if u have already check ur fuse on the power make sure its a big enough amp fuse for the amp
May 17, 2010 | MTX JackHammer JH600 Car Audio Amplifier
The light that has the lightning icon keeps blinking continous. what could be the problem
Hello djmalibu77,
You do not say if the amp has been installed and working properly for some time or if the problem began immediately upon installation.
If the amp was just installed, I'd suspect a wiring problem. Either a faulty ground or too low of an impedance.
If the amp has bee working properly and the problem just started, I'd start by removing all connections except ground, power, and remote and see if the amp powers up properly. If it does, reconnect the wiring one at a time to determine where the faulty wire or component is located. A grounded or shorted input, shorted voice coil, or a short or ground in the output wiring will cause an amp to go into protection. If these all check out, it's probably a fault in the amp itself.
Hope this helps.
Oct 31, 2009 | MTX JackHammer JH300 Car Audio Amplifier
Mtx jh600 feed back in subs light on amp the bolt is blinking
check that the ground wire is bolted tightly to the chassis of the vehicle.
Aug 08, 2009 | MTX JackHammer JH600 Car Audio Amplifier
May 26, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Mtx audio jh202 amp
my amp is blowing fuses?? any hints?
Feb 03, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Car Audio & Video Logo
166 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
