Question about Refrigerators
Ice maker makes cubes but won't push out cubes, this is in a gibson fridge
  • 262 Answers
If the Freezer is below 13 degrees F then replace the Ice maker.
Posted on Sep 05, 2010
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Reset the ice maker back to making ice again
Turn the water supply off to the fridge, make sure the bailer wire (ice level bar) is in the down position. let the Ice maker run thru its cycle. When the cycle is complete the fingers that push out the cubes should all be down. Unplug the fridge for about 5 min. During this time turn the water supply back on. Plug the fridge back in and let it run thru a few cycles. This should reset the icemaker cycle. As a note: you should be able to hear the water turn on with a solid thump as the valve opens to fill the cube trays inside the icemaker.
Sep 18, 2014 | Samsung Refrigerators
Ice maker is not dropping ice
there are 2 things that could be problem, 1 is a heater element that heats the bottom of frozen cubes slightly to allow the cubes to be pushed out into the tray by plastic fingers under the cubes and controlled by a motor. best bet would be to get model number of fridge and/or ice maker and look for direct replacement online. There is a company out of Chicago that offers replacements for lots of models. Sorry I dont have their name, but google the results for ice maker for your make/model fridge.
Jan 28, 2013 | Refrigerators
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
