Question about Car Audio & Video
My car won't start and the diagnostic read p0335 crank shaft position censor A CIRCUIT MALFUNCTION
  • 15,935 Answers
What does that mean?
The crankshaft position sensor (CKP) measures crankshaft location and relays this information to the PCM (Powertrain Control Module). Depending on the vehicle, the PCM uses this crankshaft position information to time the spark properly or on some systems it is only for misfire detection and does not control spark timing. The CKP sensor is stationary and works in harmony with a reluctor ring (or toothed ring) that is attached to the crankshaft. As this reluctor ring passes in front of the CKP sensor, the magnetic field created by the CKP sensor is interrupted and this creates a square wave voltage signal that the PCM interprets as crankshaft position. If the PCM detects that there are no crankshaft pulses or if it sees a problem with the pulses on the output circuit, P0335 will set.
Symptoms
NOTE: If the crank sensor is used only for misfire detection and NOT spark timing (this varies with the vehicle), the vehicle should start and run with MIL (Malfunction indicator lamp) illumination. Also, some vehicles require several key cycles to illuminate the MIL. If this is the case, there may be no MIL illumination until the problem often enough over time. If the crank sensor is used for BOTH misfire detection and spark timing, the vehicle may or may not start. Symptoms may include:
* Vehicle may not start (see above)
* Vehicle may run rough or misfire
* MIL illumination
Causes
A P0335 "check engine light" code could be caused by:
* Damaged CKP sensor connector
* Damaged reluctor ring (missing teeth or not turning due to sheared-off keyway)
* Sensor output open
* Sensor output shorted to ground
* Sensor output shorted to voltage
* Failed crank sensor
* Broken timing belt
* Failed PCM
Possible Solutions
1. Using a scan tool, check if, when engine is running or cranking, that there is an RPM signal.
2. If there is no RPM reading, then visually inspect the crank sensor and connector for any damage and repair as necessary. If there is no visible damage, and you have access to a scope, you could check the CKP 5 Volt square wave pattern. If you do not, then, obtain a resistance reading of your crank sensor from a repair manual. (There are so many different types of crank sensors that there's no way to put here which resistance reading is correct). Then check the resistance of the CKP sensor by disconnecting the sensor and measuring resistance of the sensor. (It is best to check resistance readings from the PCM connector. This rules out any wiring problems from the start. But it does require some mechanical skill and shouldn't be performed if you\'re not familiar with automobile electrical systems). Is the sensor within resistance specs?
3. If not, replace the CKP sensor. If so, recheck resistance reading from the PCM connector. Is the reading still okay?
4. If not, repair open or short in the wiring to the crank sensor and re-check. If the reading is okay, the problem is intermittent or the PCM may be at fault. Try reconnecting and checking for RPM signal again. If there is now an RPM signal, wiggle test the wiring harness to try and induce the fault.
This code is basically identical to P0385. This code P0335 refers to Crankshaft Posistion Sensor "A", whereas P0385 refers to Crankshaft Position Sensor "B". Other crank sensor codes include P0016, P0017, P0018, P0019, P0335, P0336, P0337, P0338, P0339, P0385, P0386, P0387, P0388, and P0389.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 05, 2010
Testimonial: "very helpful"
I have these codes reading now po700 po335 and po727 any idea what to check first on 03 kia sorento. my car lost power then shut off, then wouldn't start
p0335 is a crank shaft sensor error. This sensor is what tells the ECM when to send spark to plugs. That is why it wont start.
Apr 02, 2016 | Kia Cars & Trucks
Crank and cam sensor replaced . cars starts and run but still reads code 335 . cranksensor circuit malfunction. and idea whats the issue why this code is still coming up.?
the sensor may be good its the circuit code which means can be a wiring /connection problem not just the sensor the following link is courtesy of obd-codes.comP0335 - Crankshaft Position Sensor A Circuit Malfunction OBD-II Trouble Code Technical Description Crankshaft Position Sensor A Circuit Malfunction What does that mean? The crankshaft position sensor (CKP) measures crankshaft location and relays this information to the PCM (Powertrain Control Module). Depending on the vehicle, the PCM uses this crankshaft position information to time the spark properly or on some systems it is only for misfire detection and does not control spark timing. The CKP sensor is stationary and works in harmony with a reluctor ring (or toothed ring) that is attached to the crankshaft. As this reluctor ring passes in front of the CKP sensor, the magnetic field created by the CKP sensor is interrupted and this creates a square wave voltage signal that the PCM interprets as crankshaft position. If the PCM detects that there are no crankshaft pulses or if it sees a problem with the pulses on the output circuit, P0335 will set. Symptoms NOTE: If the crank sensor is used only for misfire detection and NOT spark timing (this varies with the vehicle), the vehicle should start and run with MIL (Malfunction indicator lamp) illumination. Also, some vehicles require several key cycles to illuminate the MIL. If this is the case, there may be no MIL illumination until the problem often enough over time. If the crank sensor is used for BOTH misfire detection and spark timing, the vehicle may or may not start. Symptoms may include: Vehicle may not start (see above) Vehicle may run rough or misfire MIL illumination Causes A P0335 "check engine light" code could be caused by: Damaged CKP sensor connector Damaged reluctor ring (missing teeth or not turning due to sheared-off keyway) Sensor output open Sensor output shorted to ground Sensor output shorted to voltage Failed crank sensor Broken timing belt Failed PCM Possible Solutions Using a scan tool, check if, when engine is running or cranking, that there is an RPM signal. If there is no RPM reading, then visually inspect the crank sensor and connector for any damage and repair as necessary. If there is no visible damage, and you have access to a scope, you could check the CKP 5 Volt square wave pattern. If you do not, then, obtain a resistance reading of your crank sensor from a repair manual. (There are so many different types of crank sensors that there's no way to put here which resistance reading is correct). Then check the resistance of the CKP sensor by disconnecting the sensor and measuring resistance of the sensor. (It is best to check resistance readings from the PCM connector. This rules out any wiring problems from the start. But it does require some mechanical skill and shouldn't be performed if you\'re not familiar with automobile electrical systems). Is the sensor within resistance specs? If not, replace the CKP sensor. If so, recheck resistance reading from the PCM connector. Is the reading still okay? If not, repair open or short in the wiring to the crank sensor and re-check. If the reading is okay, the problem is intermittent or the PCM may be at fault. Try reconnecting and checking for RPM signal again. If there is now an RPM signal, wiggle test the wiring harness to try and induce the fault. This code is basically identical to P0385. This code P0335 refers to Crankshaft Posistion Sensor "A", whereas P0385 refers to Crankshaft Position Sensor "B". Other crank sensor codes include P0016, P0017, P0018, P0019, P0335, P0336, P0337, P0338, P0339, P0385, P0386, P0387, P0388, and P0389.
Read more at: http://www.obd-codes.com/p0335
Copyright OBD-Codes.com
Aug 19, 2015 | 2005 Chevrolet Impala
Where is the 2nd crank shaft sensor located, and is there a diagram to show where these sensors are located?
is it a no crank or crank no start?
Possible causes for code P0335
- Faulty crankshaft position sensor
- Crankshaft position sensor harness is open or shorted
- Crankshaft position sensor circuit poor electrical connection
- Signal plate may be damage
- Starter motor may be faulty
- Starting system circuit
- Dead or weak battery
Read more: http://engine-codes.com/p0335.html#ixzz3Cxw6SN6O
Sep 10, 2014 | 2004 Buick Rendezvous
Iget a code po335
code p0335 refers to crank shaft position sensor(CKP)- circuit -malfunction cause may include Wiring---CKP sensor Engine control module
Mar 23, 2013 | Mazda 626 Cars & Trucks
Hi have 2001 chevy s1o pick up have engine light on with code po335 crank sensor circuit problem had sensor and pig tail connector replaced still have same problem around 2500 rpm engine brakes up engine...
Symptoms:
* MIL illumination
Causes: A P0335 "check engine light" code could be caused by:
* Failed PCM
Possible Solutions:
Test it and keep us updated.
Feb 05, 2011 | 2001 Chevrolet S-10
I have a 2000 Mitsu. Galant. Trouble codes p0335 and p0340 for cam and crank sensors.Are there any common problems?
Hi, I found a couple of good articles on those codes. Rather than just copy and paste here are the links:
P0335 - Crankshaft Position Sensor Electrical Error
http://www.bba-reman.com/content.aspx?content=NEXT_DTC_P0335
P0340 - Camshaft Positio Sensor Circuit Malfunction
http://www.obd-codes.com/p0340
Jan 03, 2009 | Mitsubishi Galant Cars & Trucks
Trouble code p0335
Well thats a crank-shaft position sensor, if you didn't know. I have a mitsubishi but don't know a whole lot about this problem. But this might help:
http://www.club3g.com/forum/problem-reports/89234-p0335-crankshaft-position-sensor-circuit-malfunction.html
Aug 16, 2008 | Mitsubishi Eclipse Spyder Cars & Trucks
Car Audio & Video Logo
304 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
