Question about Refrigerators
The 118L Husky Bar Fridge HUSC1 we have has started freezing everything, is there a reset button which may help to resolve this issue
  • 2,299 Answers
There is an adjustment inside the fridge. You can change the temp setting on it. There is a dial from 1 to 9. It will say warmer and cooler. Just turn the dial.
Posted on Sep 05, 2010
Samsung American fridge freezer SR-S2028CSS keeps beeping and randomly turning the fast freeze on and off.
quite possibly it needs some freon added to the system and only service people can do this
Jan 06, 2016 | Samsung Refrigerators
How do I reset fridge model #106.51132210 it drips water from top and freezes on top shelf of fridge side
I'm not sure if resetting will help, but the easiest way is to just flip the breaker off and then back on.
Dec 04, 2014 | Refrigerators
I have a samsun fridge and the code pc er came on and the light is not working nor the temp why????
"PC-ER" its a error in the PCB (computer).
Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
Samsung says that... if the code "PC-ER" appears on the display panel or if you cannot resolve the issue, the refrigerator needs to be repaired. Contact a Samsung service technician.
Hope this helps.
Jun 09, 2011 | Samsung Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Fridge is freezing everything.
Sounds like it could be a problem with the thermostat. This is what shuts the compressor off when it reachers the proper temperature.
Aug 28, 2009 | Refrigerators
My model rs2555sl samsung fridge does not start up after power outage.
Samsung RS2555Sl suddenly stoped working once the power is switched off, If switched on again, only the Ice making sensor light flickers. If both Pwercool and power freeze buttons are pressed for 12 seconds it stars and running normally. Will it automatically start working if I change the Ice making sensor?
Jul 10, 2009 | Samsung RS2578BB Side by Side Refrigerator
G5 Mac Desktop freezes at random
First you need to run some maintenance (which in itself may solve it) to rule out software issues, so start here...
Resolve startup issues and perform disk maintenance with Disk Utility and fsck
Mac OS X: How to start up in single-user or verbose mode
If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...
What is Safe Boot, Safe Mode?
Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack
Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Feb 04, 2009 | Apple Power Mac G5 Desktop
My fridge stays on and freezes everything inside
not a breathing room issue, if anything that would cause it to shut down and not cool at all, where you got just the opposite, it never shuts off. is it an electronic model, or is there a control knob you manullay turn to adjust temp
Feb 23, 2008 | Sanyo SR-4910M Compact Refrigerator
Produce freezing
I had the same problem when one of my kids changed the setting of the chef's pantry (full-width drawer) to higher setting and everything started freezing. The setting should be at "lowest setting". Give it a try. deborah.
Feb 07, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Help
You will need to reset your device and also get a firmware upgrade on your device.....To reset the device when it freezes just hold the power button down for 15-20 seconds or until it resets....the latest firmware for the device resolved much of the freezing issues....also there are two modes for you to use the device the msc and mtp.....try deleting in mtp mode.
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Refrigerators Logo
164 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
