Question about GE Profile WPSR3120WWW
Ge profile whsb8000bocc
Washing machine stops mid cycle. Is there a filter that may need cleanig? I have looked and cannot find one.
Thanks
  • 1,543 Answers
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
Posted on Aug 28, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Aug 29, 2008
    Note: inlet screen is inside opening of water valve, where the hose connects to the machine. Some hoses may also have a screened hose washer, so you might want to check both ends of the fill hose for that also.
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
Spin cycle stops and moter humms
clean the filter out may be clogged
Jun 16, 2012 | GE Profile Prodigy WPSE4200A
Stops in mid cycle can advance timer and will start running again
unplug the machine over night and try again. check to make sure there are no wires lying on top of the IC's on the control boardl. could also be a bad control board (timer)
May 25, 2010 | GE Profile Prodigy WPSE4200A
Washer will pause in mid cycle, once you push the pause cycle it will run for a while then will pause again, after about 5 to 6 times a load it will complete.
Hi
Thanks for using FixYa. You’ll need to clean the filter which is located on the front bottom of the washing machine right below the washer window. It is held up by three screws. Take out the screws and clean the lint. You’ll find in the lint some small clothing, coins and other small things.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 15, 2009 | GE WSXH208A Front Load Washer
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Will not drain during spin???
Most likely your outlet filter of the machine is choked with dirt or something; clean out the filter & refit. Of course after taking of the wall plug & siphoning out the water from washer.
Sep 21, 2006 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
151 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
