Question about Sony Cyber-Shot DSC-S40 Digital Camera
I turn my Sony cyber-shot camera on and it says on the screen 'Turn the power off and on again". What do I do?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 05, 2010
Every time i turn on sony cyber shot the screen states turn the power off and on again whats wrong
Hi change the battery and check it again if steel the same the spring that keep battery connected may need to stretchgood luck
Oct 19, 2011 | Sony Cyber-Shot DSC-S500 Digital Camera
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
Sony Cyber-shot DSC-W150. when powering on the
allienment with the mother board and also failure of the sensors of the lens unit,so contact sony service
Mar 01, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber Shots camera, turn the power off and on again problem
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Sep 13, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Every time I try to turn the camera on it beeps and the screen says access... then says turn the power off then on again. Why?
This problem is related to optical zoom motor,The part detail is given below:
Part No. Description
A-1231-924-A LSV-1160A
Replace the said part number and your camera work fine again.
Thanks for using fixya.
Jul 29, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When i turn on my camera it says Turn the power off and on again
turn it on
take hold of the end of the lense, then pull and twist gantly you may hear it click but dont force it then turn off and on again this may solve your problem
Oct 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber -Shot
try gently pulling and twisting the end of the lense and i mean gentle dont pull till it pops than switch it off and on again and you problem should be solved
Jun 21, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
67 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
