Question about Ovens
How to replace electronic ignition pilot on a Gaffer Sattler built in oven circa 1982
  • Brbnkguy Sep 05, 2010
    Obviously this idiot did not read the question!
    Wow, this feels like a waste of time.
  • 3,247 Answers
I would suggest that you check this site out and confirm the type of ignitor on the oven you have.
Post a comment with the part no. if you can find it, then I could help find where it is available.
I wish to clarify I am not a qualified gas plumber which means you have to be careful when repairing a gas appliance.
Posted on Sep 05, 2010
    Brigadier General:
  • 3,917 Answers
How do I lite the oven pilot
If it's an older model with a true pilot light you turn on the gas at supply line valve, open oven door, remove bottom panel to access pilot and burner. Sometimes it's easier to remove broiler drawer on these models but regardless take a lighter and light pilot. Most models are electronic ignitions which if you have it probably needs replaced if it doesn't ignite the burner in under a minute or minute and 15 secs. It could also be a bad thermostat if the burner ignites within the time period described above
Sep 10, 2014 | Magic Chef Ovens
What is a pilot generator
Simply put, a pilot generator is a thermopile that generates millivolt power to operate a gas valve.
However, on your convection oven, yours operates on an electronic spark, which is generated by an electronic ignition control module.
Jul 29, 2014 | Vulcan SG4D Gas Single Oven
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Have a 1980s model oven model #EH4W4 .My problem is the burners work great but oven does not lite anymore when temp is selected.?
If it is a standing pilot the thermocouple has most likely failed. If it is electronic ignition the the igniter has probably failed. Is the oven plugged in to the wall outlet all the way or is it direct wired? Is it standing pilot or elctronic ignition? Really need more info to correctly diagnose
Mar 11, 2011 | GE Ovens
The broiler and the burners all light but the oven doesn't.
If the glowbar is light up then you have a circuit and all components are working. So Houston why don't we have ignition? Today's new fangled ovens use silicone carbide ignition. The oven safety valve has a bi-metal inside it. In order for it to open and allow gas to flow the resistance in the circuit must change. As that glowbar heats up it changes the resistance in the circuit. If it can pull 3.5 amps or better then that bi-metal will open allow gas to hit the burner. That is yall's built in safety feature. If a glowbar looks real dim and takes a while to come on if at all then it is weak. Whirlpool also has another type of oven that uses a safety valve with a thermocouple attached to it. A pilot light is on all the time on these and no power is needed to operate this stove. Over time the thermocouples cooper-nickel tip will wear out and won't hold the oven safety valve open. Other variations of this is a standby pilot and electronic spark pilot and a flame switch added onto a safety valve. Newer models use a computer board along with AC power to fire the igniters and DC power to open the distribution valve. Your broiler is working so I am sure your stove ain't got the DSI ignition system and you have not mentioned anything about a pilot light so I am assuming you simply have a weak glowbar.
Video:
More here
Oven codes and other stuff HERE
Feb 02, 2011 | Whirlpool Ovens
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
    our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
    Dec 22, 2009 | Ovens
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    Ovens Logo
    166 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
