Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Will not run smell like hot electric wire - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
  • 377 Answers
Sounds like the cutting blades are bound up tight. UNPLUG THE UNIT UNDER THE SINK!
Use an allen wrench on the bottom of the unit in the motor shaft to turn by hand until it moves freely. Look into top of unit to see if there are any foreign objects that you have freed up in the cutters and remove. Plug in and use.
Posted on Sep 06, 2010
Smells electrical when running
Unless it is very new, this would indicate some of the wiring is getting too hot. Since stoves are not normally wired through a safety switch, get it checked by an appliance electrician. You do not want a fire.
Apr 19, 2015 | Kitchen Ranges
On and Off smell of smoke
Have a look under the van and see if you have any plastic melted to the exhaust. (like a plastic shopping bag)
If you don't see anything, I would look close around the exhaust under the hood to make sure no wires are making partial contact with the hot exhaust.
Final check would be the wires from the O2 sensors making contact with the exhaust.
You will have them before and after the converter Fairly close to the engine and no farther back than the driver seat area.
Mar 19, 2014 | 2009 Chrysler Town and Country
I smell an odor possibly electrical but I was unsure and had the gas company come and check. The gas company serviceman states the gas connections are good, nos gas smell in any areas of the house. The...
You should have an Amp draw on the system and it's motors. Your nose will be your guide in figuring out what component is getting hot. Smell circuit board and electric motors.
Jan 16, 2011 | Ruud UBHC Air Conditioner
How to repair electric fans that runs so slow even when it's turned on to it's max speed?what seems to be the problem?
i have the same problem...i think the wires are ok and it still have some grease in it...but it still running slow even if i set it to its max speed...and another thing is it really gets hot sometimes and i smell some hot electric wire smell coming from its back cover
Jul 29, 2010 | Dryers
Smell of electrical burning.. no more heat in house!
First of all keep this in mind.
You will need to locate the wires that got hot. If you can't or if your not sure, I suggest that you call a service company. If they ok the unit and it catches on fire after wards, their insurances will cover you unit and or home if god forbid it burns. This is to be on the safe side.
Now, this is where I would look. Your element should be on it's on circuit. There should be a disconnect within reach of the air handler. Some are fused and some are not. The wires that got hot enough for you to smell them should show signs of being hot like the plastic will be melted around the wire. You said that the heater was running. Was this the first time you have used it this year? If so, are you sure it was not the dust burning off the elements? They will smell like something burning when you first turn them on each year. Although if your sure you smelled wires getting hot, please continue looking for just that. Keep in mind that the elements have 220 volts coming to them. It comes into the unit and go to a switch or relay. From there the power goes to the elements and then to a neutral. These are the wires you will need to pay the most attention to. Good luck.
Nov 23, 2009 | Heating & Cooling
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
When it runs, it runs too hot even on low and burning smell
needs new thermostat DO NOT USE IT IS A FIRE WAITING TO HAPPEN
Sep 18, 2009 | Kenmore 62602 Electric Dryer
99 cavalier Smoke coming out from under dashboard!
now this may be a long shot... but i had a similar problem on my cutlass. but it wasnt wiring...... it was from the tube running from the head of my engine...... the smell and smoke were coming from hot oil coming out of the crank case vent tube and then being sucked into the air inlet for the heater/ ac.
since a electrical wire's protective cover is petroleum based as is oil.... they smell very similar
Jan 08, 2009 | 1999 Chevrolet Cavalier
LEQ9508PWO breaker pops
IF IT SMELLED HOT, I WOULD LOOK A THE ELECTRICAL WIRING FROM YOUR OUTLET, THROUGH THE ENTIRE DRYER. START WITH PLACES OF EASY ACCESS AND WORK YOUR WAY INWARD. LOOK FOR MELTED OR BARE WIRES THAT MAY HAVE COME INTO CONTACT WITH THE METAL FRAME OF THE DRYER.
TRY SELECTING FLUFF AIR (NO HEAT) AND SEE IF IT WILL RUN O.K. IF IT DOES, I WOULD SUSPECT THE HEAT CIRCUIT. TAKE THE BACK PANEL OFF AND INSPECT THE WIRES AROUND THE HEATER ASSEMBLY.
Apr 07, 2008 | Whirlpool LEQ9858P Electric Dryer
Burning Smell
Keep it unplugged and look for burned wires, or rubber wires hardened from extreme heat. This will be a good start in finding what is going wrong. One more thing to check is if the compressor is heating up after running for a while. Let it run for 20 min or so, shut off the power and feel the compressor. Is it hot?
Jan 12, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
122 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
