Question about Maytag CWE5800A Electric Double Oven
My oven keeps beeping and flashing an f-7.....what can i do to stop it?
  • 262 Answers
Turn off house breaker to the unit at the breaker box of your home. This will be a double breaker.
F7 Touch pad or Control board...... Most techs start with touch pad.
Posted on Sep 05, 2010
5 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: amana oven
Error F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Oct 17, 2007
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
vitg55
  • 78 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
kojak18
  • 31 Answers
SOURCE: F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Posted on Jun 22, 2010
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
Jenn air expressions double oven
F-7 error code means that the Function Key is stuck or shorted out. You will have to replace the touch pad or if the touch pad is part of the clock, you will have to replace the clock (ERC).
Aug 18, 2014 | Jenn-Air Ovens
When I bake, my oven will start beeping and flash F2, what is that and how do I stop it?
Which manufacturer built your oven? The F2 error usually means that the oven temperature sensor is claiming the oven is too hot (or got too hot in the past). This usually requires replacing the temperature sensor. Sometimes, the control unit (clock) needs to be replaced.
I hope this helps. Please add a comment with the make and model of your oven for additional support.
Mar 18, 2013 | Ovens
F-7 code has been flashing, along with constant beeping. This has happened about 5 times over the past 2 months. Eventually it stops but now we resort to flipping the fuse off to get rid of the noise. ...
Hello Marylou,
The F7 code means the same thing on all domestic (USA) brand ovens.What is means is that a button on the touch pad is shorted (welded together) out. Since you did not include brand or model#
i will give you the following advice, if your touch pad is a seperate part that plugs in clock (also called the oven control,or eoc..electronic oven control) then just the touch pad can be replaced,on certain brands or even some models within a brand the touch pad is integrated into the clock/oven control or eoc in that case the complete touch pad/control asm. is what needs to be replaced
Hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Ovens
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
Ge oven JTP15 beeping and flashine F7 error
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE JTP15 Electric Single Oven
Oven
Aug 07, 2008 | Ovens
Dacor oven beeping
Keeps flashing F1 and beeping help! how do I make it stop?
Apr 25, 2008 | Ovens
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
Maytag CWE5800A Electric Double Oven Logo
354 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
