Question about Emerson EWF2703 27" TV
Remote will no longer work
RE: Emerson 27" flat screen tv -- the remote will no longer work - model #EWF2702 it says on the back of the TV -- I had to select below the number 2703 however to get this to submit
Any suggestions (we have tried new batteries -- with brand new batteries it would work off and on after shaking it - wiped off the contacts inside - now it will not work no matter what.)
  • 3 more comments
  • JoannC May 12, 2008
    thank you very much - I am not that savvy technically - in order to use or program a universal remote doesn't the original remote need to be in working order to do so???
    Thank you very much ktoth04 for both replies -- I have printed off the info for my husband who is certainly more technical than I am. I appreciate the fast response and resolution to our problem. Thanks again.
  • sadpearls Aug 15, 2008
    Having problem with universal remote after using for over a year, tried new batteries. It is stuck in Video 1 mode. I even bought a new universal remote, entered the correct code etc. but no luck. Cannot watch the olympics, only the DVDs play through the Video 1 mode. So what or where do I go from here.
  • greg_a Sep 24, 2008
    My original remote stopped working so I got a replacement OEM remote. That worked for awhile but has also since stopped working. I then tried a universal remote and THAT worked for a time but no longer works. I don't know what else to try. Is there a way to reset the remote sensor in the tv?
  • travelerga19 Apr 08, 2009
    I and a friend have the same model EWF2703, both quit responding to the remote. It is not a remote problem.it is the sensor in the tv set that is the problem. who sells replacment sensors?
I HAVE THE SAME PROBLEM....the original remote or the replacement remote will not work at all. Is there some kind of sensor that can be replaced??
Posted on Sep 24, 2008
  • reeze Oct 20, 2008
    I found the exact Emerson # NE116UD remote on newremotecontrol.com priced reasonably. All the universals state that it is compatible to Emerson but it still doesn't work.
    Thanks for the help
  • 39 Answers
Your best bet is to buy a universal remote that would work with your model television or a replacement remote from your manufacturer.
This one is pretty cheap (and may be your exact remote?)
http://www.replacementremotes.com/store/productdetailp.cfm?productid=28946
You could probably buy a universal remote cheaper at walmart or target, but the cost savings will cost you the time and hassle to program the remote (and if you buy a universal, you must make sure it works with emerson TVs).
Posted on May 12, 2008
  • Katharine Toth May 12, 2008
    No, a universal remote comes with complete instructions in how to program it, and they have a list on the package of TVs they are compatible with. You should make sure your TV is on the list... if you can't find one that has your TV listed, i recommend buying the one I linked to, above.
  • Katharine Toth May 13, 2008
    No problem, good luck!
I need help program my rca remote to my emerson ewf2702
To give you a quick answer I would need to know the model rca remote you had. But you can use this site to find it. RCA Remote Code Finder Under model put your remote model witch should be on the underside of the remote. Then select tv and go from there.
Sep 07, 2017 | RCA Televison & Video
Remote control model n9278ud need code for tv model ewf2702 emerson
try using the search button pressing it repatadly at the tv usually after a while the code will program itself by scattering all other codes to find a compatible code or you can search for the remote control model code online
Aug 05, 2012 | General Electric Televison & Video
Remote doesn't work for model ewf2702
Check the infrared emission from the remote control. If it is OK, the infrared sensor inside the TV is faulty. To get more details about how to check a remote control, visit the site named 'Electro-help'. You can search for it either by Google or yahoo.
Jun 08, 2012 | Emerson EWF2703 27" TV
I have an Emerson EWF2702 model flat screen TV that just developed a remote control signal recognition problem. Is it the remote (w/new batteries) or the IF sensor inside the TV box? Is it a diy fix or...
There is a simple way to check whether your remote is still sending a signal to the TV. The infra-red flashes from the remote cannot be seen with the naked eye, but they ARE visble when viewed through a video camera. It's easier to do this with 2 people, but it can be done by one person with the camera in one hand and the remote in the other. Just point the remote at the camera and press some buttons. If you can't see the flashes through the camera view finder, it's likely the IR transmitter in the remote is dead. If you can see the flashes, it's likely to be the IR receiver in the TV.
I've used an analogue (tape) video camera for this test, but there's no reason why it wouldn't work on a digital video camera or possibly even a digital/phone camera.
Hope this helps.
Regards,
BElectric
Nov 17, 2010 | Televison & Video
Need a romote code for HRS URC-383 for my emerson 27 inch flat screen.
If you are using Sky Remote then you can try to use these codes 0742, 0205 or 0206 for you Emerson TV which will work on all versions of the handset.
these are usually generic codes and may well work on the HRS URC-383 remote as well
Oct 04, 2009 | Emerson EWF2703 27" TV
Is There a way to go to video/input without a remote.
My answer will be generic.
With many of these TV sets the original factory remote is required to change the input mode of the set, or to access any of the user menus.
On some models of sets, putting the channel selection down to below channel 2, puts the TV in to the external input modes.
Jerry G.
Feb 10, 2009 | Emerson Televison & Video
Emerson EWF2702 27" TV
I had the same problem it ended up being the speakers I had on top of my tv, so I had to move them. If you have anything on top of your tv with a signal move it. :)
Nov 10, 2008 | Emerson EWF2703 27" TV
Remote not communicating with TV
ok your problem is so simple,just clean the circuit board of your remote control.unscrew the remote control,get the circuit,then use a cotton with alcohol,then scrub,that's it......
Oct 27, 2007 | Emerson EWF2704 TV
Using my universal remote to control my iLo 27" Wide-Screen LCD TV
I have a ILO 27" TV Comcast had no suggestions for programming their remote. I went thru the ENTIRE code book and finally came up with one that worked: Emerson Code #0463 for my COMCAST universal remote.
Jul 14, 2007 | iLO V27DMBX Television
Emerson EWF2703 27" TV Logo
555 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
