Question about Amana DLE330RAW Electric Dryer
My dryer will run for a while but then it stops. I can still hear the timer ticking and if I push the button again the dryer will run again.
  • 262 Answers
My Best Guess would be a bad power connection, or just a bad connection, A bad timer or Bad Motor
I would ckeck the power cord connections first and even the outlet. Making sure all the wiring is sucure.
Of course make sure you turn off the breaker to the outlet befor serviceing and unplug the machine befor serviceing
Posted on Sep 05, 2010
Haier dryer ticking noises
ticking you hear is the timer motor,drive motor is most likley geeting too hot.check vent ,dryer pushed back too far?hose kinked ?stopped up?too long?vent should be short,straight and of hard pipe.clean vent twice a year,heating element will love you.you will not love to replace it.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
Have a kenmore dryer model 110.66912692. Wife was using it for multiple loads today and then it stopped working. You can hear the timer ticking, and the push to start button makes a click noise like it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Dryers
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Sep 22, 2008 | Kenmore 62602 Electric Dryer
Kenmore series 70 mod#110.62722100
check the door switch first if it is ok ..(doors not popping open) then the PTS (push to Start) switch is most likely bad as it wont hold in after it was pressed
Jan 25, 2008 | Dryers
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Amana DLE330RAW Electric Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
