Question about Dell Dimension 2400 PC Desktop
My desktop computer has encourntered the OFOO: 1A44 error. Unfortunately, prior to finding this site (using my laptop), my desktop no longer boots up. So I cannot install the missing driver while on that computer. Is there a way to download these tools to a CD instead of it going right to the laptop I am on?? I need to be able to install a cd on the desktop and get this to work on that, not my laptop.
  • 734 Answers
It looks like you need a new hard disk. While bad blocks on the disk can be bypassed by repair programs. It's inevitable that more blocks will fail in the future. If the Dell computer is still under warranty they will send you a new disk. If you remove the disk and use a USB adapter you can copy your data to another computer.
Good Luck
Posted on Sep 05, 2010
Dell error code ofoo 0131d
It is unfortunate that the computer displays an error code as "ofoo 0131d". Request you to use the below link and install My Dell:
http://dell.to/1cn35y5
Then run a diagnostics using My Dell and let me know the test results.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Oct 04, 2014 | Dell Inspiron 8600 Notebook
How do i fix error ofoo:0244 and ofoo:1a44 (msg block 16867582, 46028639 & 111595250), please? I get these codes when I start my pc
I would suggest you first try the Start Up Repair for Windows XP.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.
2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.
3. When you see the blue screen, let the computer load everything and when it's done choose "To set up Windows XP now, press ENTER"4. Press F8 to agree to the License Agreement 5. Choose "To repair the selected Windows XP installation, press R"
Windows will then start the repair process. Do not worry all your data and settings will be retained.
If above solution does not work then,Use Recovery Console.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.3. When you see the blue screen, let the computer load everything and when it's done press R to repair Windows XP using Recovery Console4. On the Recovery Console, choose the installation you would like to log on to (for example c:\Windows)5. Type Chkdsk /p /r on the Recovery Console and your computer will begin to check the hard drive for error and recover data.6. Once Chkdsk is completed, type exit then press Enter. Computer should restart. No need to boot from CD at this point. You can take out the Windows installation CD.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Microsoft Windows XP Home Edition
My Dell Inspiron 6000 has Samsung Model MP0603H hard drive. The computer was working fine till this morning when it would not boot. I ran diagnostic using the Dell CD and the results stated: Error Code...
Those codes all apply to the hard drive itself..
Replacing the hard drive is all you should have to do.
Below is a link to a brand new hard drive that will work in your Inspiron 6000
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350216497944&rvr_id=119484484159&crlp=1_263602_263622&UA=%3F*F%3F&GUID=1ca6610412a0a0aad456d986fffd8c0c&itemid=350216497944&ff4=263602_263622
Aug 03, 2010 | Samsung ( MP0603H) 60 GB Hard Drive
Dell computer error codes 650F-0244 and 650F:1A44. Computer was running fine the day before and then without warning I had a blue screen and could not reboot, not even in safe mode. Any ideas on how to...
That's usually a damaged system file or a bad sector on your hdd. I recommend booting of your xp disk go to recovery console once you boot and run chkdsk /p and reboot when done.
Oct 12, 2009 | Computers & Internet
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
When running diagnostic for Dell computer was given error code OF00:1A44. I ran the diagnostic becasue I was unable to get past the blue screen in Windows - error there is Unmountable_boot_volume.
Boot to the XP CD, Enter recovery console by pressing "R" at the 1st prompt, run the command CHKDSK /P and see if the system will boot normally after the command finishes running. If nothing changes, then the hard drive will need replacement
Jun 18, 2009 | Dell Inspiron 6000 Notebook
Can't boot windows xp
it sounds like the easiest solution would to either run the repair sequence from a windows xp disk (may not be a perminant fix) if that doesent work just use the xp disk to format the drive and install a new operating system
May 10, 2009 | Microsoft Windows XP Home Edition
Dell Dimension 2400 PC Desktop Logo
127 people viewed this question
Alun Cox
