Question about Dishwashers
The soap stays in the dishwasher soap door compartment and does not dispense
  • Dishwashers Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Sep 07, 2010
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
The detergent compartment on our dishwasher will open during operation. We have run the dishwasher three times and the detergent capsule remains in the compartment and is only partially dissolved. It...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid Dishwashers
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
The soap compartment will not open during the wash cycle.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these.
Please revert for any further assistance.
Daniel
Aug 28, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Soap dispenser door pops open
Try cleaning the compartment. If the latching is not OK, it could be a latch problem, or alignment, or total dispenser. Contact service provider for assistance.
May 26, 2010 | Maytag MDC4650AW Built-in Dishwasher
Soap dispenser will not open during cycle
I have the same dishwasher, have for about 2 years. It took me about a month to figure this out... But, you cannot run it with the flatware rack hanging on the bottom dish rack, you have to move it to hang on the door and you cannot have anything in the compartment under the soap dispenser that is tall enough to block it from opening. Annoying design for sure!
May 12, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
Secondary soap dish won't open
i think you mean jet dry compartment.change dispenser. in some cases there is a kit but its better to replace new dispenser
Mar 02, 2010 | Dishwashers
Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
Soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Jun 04, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
UNDISSOLVED SOAP RESIDUE AND
Dispenser door sticking. Run it a few cycles by putting the tablet in the cutlery basket.
Mar 22, 2008 | GE 24 in. GHDA986KSS Built-in Dishwasher
Dishwashers Logo
146 people viewed this question
Top Dishwashers Experts
Owen Barnes
