Question about RCA L32HD31 32 in. LCD HDTV
My "32" rca flatscreen has no picture but has sound,the picture cuts in and out when it wants to
  • james goodberry Sep 05, 2010
    i took the back off my tv but have no clue what the look like in the back off my t.v
    what do swollen capacitors look like
    President:
  • 1,961 Answers
The backlight of your tv is about to be busted and must be replace but before replacing check first the ballast inverter board of the backlight lamp.you need to open the back cover of your tv to access the inverter board.in many cases a loose connection in the supply of the inverter board causes the problem that you've mention re soldering the connector of the inverter board from the power supply will cure the problem.next is the inverter board itself and the lamp you can replace them and they are available online at shop jimmy.com heres a link to the online store thans and pls rate my help
Posted on Sep 06, 2010
    Genius:
  • 1,112 Answers
HI:
Have the power supply and the inverters checked for swollen capacitors, this is the most common problem with no backlighting. Look for caps where the tops of them are puffy or swollen they all should be flat on their tops.
Posted on Sep 05, 2010
  • Lavell Turner
    Lavell Turner Sep 06, 2010
    Capacitors look like some what like Batteries standing horizonaly on the boards, they are usually black in color or brown. With power off rub your finger gently across the tops of them especially the ones near the output connector leading to the main board. They should be flat on their tops, if you feel a bump or puffy top these will need to be replaced. Also there are inverter boards inside the unit also there are usually two caps on these boards you should check also for puffy tops. Replace any caps you find with the same value that is printed on their sides. Rem that caps are polarized with Pos and Neg leads so inserting any new ones will have to go back in the right way, usually there is marking on the board to indicate where the negitive side of the cap is , on the cap itself the stripe side is NEG or ground.
3 Suggested Answers
  • 1684 Answers
SOURCE: I have a westinghouse 32 in flatscreen tv it is
This problem is caused by a bad backlight power supply. Check out this page on our web site:
www.ccl-la.com/capacitors.htm If you can solder then you should be able to do the repair yourself.This page gives pictures and parts information. You will need to open your monitor and replace the parts call capacitors that are damaged as directed on the page. If you don't want to do the repair we do offer a repair service for $40 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 28, 2010
MNfisherman
  • 11896 Answers
SOURCE: have a bush 32 in flatscreen tv i have sound but
It is most likely a faulty capacitor on the convergance or other system board that will need to be found with capacitor tester. It will need to be replaced.
Posted on Sep 09, 2009
Testimonial: "thanks for ur help really helpful and quick reply thanks again "
I have a 2 year old 32" rca flatscreen tv when turned on picture fine after 5 minutes picture flickers stays that way
Sounds that the fault is not with any loose solder point; but the back light inverter or the main power supply regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 18, 2015 | RCA Televison & Video
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
My RCA HD flatscreen blink off but has sound.
please help solve this soon so i can watch my tv
Feb 13, 2010 | RCA L32HD32D 32 in. LCD HDTV
RCA 26" Flat Screen suddenly no picture
The T-con board has failed but i do not think that it is sold seperately you will have to have a tech check it out if your set is just over the warranty i would contact rca they may just pay for it
Dec 14, 2009 | RCA L32HD31 32 in. LCD HDTV
Have a bush 32 in flatscreen tv i have sound but
Sep 09, 2009 | Televison & Video
New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Jul 04, 2009 | Sanyo DP32648 32 in. LCD TV
I have a 42 inch RCA flatscreen that the picture will not come on I have unplugged TV and cable and no change.
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jun 30, 2009 | RCA F32650 32" TV
I have a LG 32 in flatscreen. It wont turn on. The green light blinks and I see the monitor light up some but no picture or sound. I can not see the menus or anything else. What can I do to fix this? I...
hi..the reason due to this problem may be
due to the circuit board.If the soldering is not
done in any part of the main board this type of
problem occurs.check the board completely.
check this out..
thank u..
rate me..
Feb 10, 2009 | Philips Televison & Video
My RCA 32", the picture seems to be riding up the screen.
hold menu botton in power once vol up once. vol up to76  ch top po3 aj pict size ith vol cont
Nov 30, 2008 | RCA F32650 32" TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Aug 04, 2007 | RCA 32V550T 32" TV
RCA L32HD31 32 in. LCD HDTV Logo
200 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
