I have a colman ac unit and the outside unit will not come on. i hear it clicking but nothing happens
  • Trenina May 12, 2008
    I have a coleman air conditioner and it comes on outside but nothing comes on inside. What could be the problem?
  • 828 Answers
On my computer screen these two problems are not the same.
To "garys2003" Clicking you hear is the contactor closing in calling for cooling. If no power is being supplied to the outside unit high voltage the unit will not run. Check your circuit breaker or fuses in the outside power box. If the outside power box is of the non-fused disconnect, check that the disconnect is inserted properly.
To Trenina: Is your unit a self contained unit outside ducted to the inside as with a Mobile Home. If so your evaporator cooling coil may be frozen over stopping air movement, turn the cooling off and set your fan to on until it defrosts, then return to normal operation and leave the fan on during cooling.
If nothing comes on inside as with a central A/C system you may have a problem with the blower motor itself.
Posted on May 13, 2008
On my honeywell thermostat cool on keeps on flashing but ac dosent come on
On a Honeywell thermostat the flashing means that the system is in a delay to turn on the compressor. This is used to protect the compressor from coming on and off too often. The normal delay is about 5 minutes. After that the system should come on. If not there is s problem.
In order to help us help you we will need a little more information. What happens either at the inside unit or at the outside unit after the thermostat stops flashing "Cool"? Any fans come on? Do you hear a "KLUNK"? Any sparks? Please let us know so we can help.
Nov 20, 2011 | Honeywell Heating & Cooling
WHEN AC UNIT IS TURNED ON WE HEAR A CLICK BUT NOTHING ELSE.... WHEN UNIT WAS FIRST TURNED ON IT WAS BLOWING AIR IN THE HOUSE NOT COLD BUT OUTSIDE FAN WAS NOT TURNING.,,,,, WE THREW ALL THE BREAKERS AND...
The capacitor in the electrical compartment has probably gone out, it will be a dual run configuration and a large round device with three terminals with multiple connections. Slao check all electrical connections.
May 18, 2011 | Goodman CKL60AR60 Air Conditioner
I installed a new colman mack thermostat in my camper witch has a colman ac unit now ac unit runs 5 min then shuts off for 3 min then starts again and keeps doing this . so I by past thermostat and it will...
if it is a programmable thermostat you can unhook thermostat and when it comes on select 3 instead of 1. As it sounds as though it is short cycling this happens in older houses with drafts. Hope this helps Tim
Sep 07, 2010 | Coleman Mach III Air Conditioner
Ac unit clicks outside but nothing engages fan or compressor on unit furnace still runs for heat setting and fan still blows but ac will not engage just hear a clicking was running for three days this...
Have you check the outside breaker? If its ok then you got a problem in your electrical system inside the unit probably the contactor is not engaging this is where the 24 volts from the thermostat calls for the 240 volts to run the condenser fan and compressor. Be careful checking this out because of the high voltage.
Jul 09, 2010 | Carrier 38CKC048 Air Conditioner
Colman unit is getting no power
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Sep 10, 2009 | Coleman Mach III Air Conditioner
I bought an older camper with a colman roof unit ac. My question is do I need to put small filters under the intake grates inside the camper below the ac cover. There is nothing in there. (bought it this...
its good to put them in, as it will keep dust from building up on the coils, thus reducing cooling.just buy some filter material at any hardware store, coarse, like a sponge, not fine paper stuff.
Jul 30, 2009 | Dometic Rooftop RV Air Conditioner
My air conditioner is not running on the outside but in the inside. temperature states 85 inside
If you turn down the thermostat to the air conditioner and the unit outside does not come on, you could have a few different issues. The usual suspect is a start capcitor. When you adjust your thermostat you should hear a click from the outside unit. If you hear a click but nothing happens, check the power disconnect out there by the unit. I recently had to replace mine because it finally just wore out. It can also be the contactor, the fan itself or the actual compressor.
Jul 02, 2009 | Honeywell Heating & Cooling
No cool air
It is the capacitor write down the wiring colors to the capacitor and then disconnect the safety disconnect on side of house. And even turn off the breaker to the condensing unit. Okay now that no power is going to the unit take out the capacitor you wrote down what wires went where and ohm out the herm side go from the center post to herm side. Should be bad wont get a reading. Get new capacitor and re install. good luck ken
If not capacitor get back to me. And please leave good feed back
Apr 29, 2009 | Coleman Heating & Cooling
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
