Question about Linksys Wireless-G WRT54G Router
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct information. "DHCP Release", "DHCP Renew" and "refresh" buttons have no effect.
  • Linksys Master
  • 7,733 Answers
Here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Posted on Oct 29, 2010
It has stopped connecting to the Internet. The cable modem and computer are fine, but the cable modem and the linksys no longer "talk" to each other. Other wireless connections in my vicinity work OK on...
Base from the description of your problem it seems that we need to reconfigure the router to work with your modem again and we need to do that manually using a computer connected wired to the router.
To do that follow these steps.
Connect the modem to the router and computer to router also, make sure all connections are correct.
Then power on the router , modem and computer and check all the lights on the router are fine and make sure power is solid green if those are fine access the router setup page.
From the computer that is wired to the router a\open internet explorer and type 192.168.1.1 and hit enter then that should ask for a username and password, just leave the user name blank and password is admin hit enter you should be now on the router page.
From there under SETUP tab look for a sub tab MAC ADDRESS CLONE , then enable that and clcik on clone pc mac and ten save settings and once its save power off the router and modem for 1 minute then after that power on the modem and then the router and check if internet is already working.
Oct 11, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect to internet via router WRT 54GS
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
May 08, 2010 | Linksys Wireless-G WRT54G Router
I just starting using this wireless router and when I set it up the router software keeps saying I don't have a connection to the internet but I'm on the internet on that computer right now. ...
Make sure that there is not direct connection between your desktop and modem ( USB ). If there is any USB connection from the modem to the computer then it will go on linee but the router will not be on line.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
Apr 30, 2010 | Linksys Wireless-G WRT54G Router
Will not read internet connection
Apr 23, 2010 | Linksys RangePlus WRT100 Wireless Router
Will not connect 2 internet
can u please elaborate on the problem .. like what is the kind of modem, how do u connect .. i.e using wired or wireless ... do you have any other pc in the house connecting
Mar 24, 2010 | Linksys Wireless-G WRT54G Router
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Belkin 54G won't connect to the internet
Are you sure your modem is giving a WAN IP from your ISP? Try power-cycling your modem with your router unplugged then bring up your router next, if you havent tried that already... After that try connecting your modem directly to a PC and set your NIC card to DHCP and see if you get an IP address thats routable to the internet (i.e not a private IP)
Mar 27, 2009 | Belkin Computers & Internet
Sharing a connection with wired and wireless computers
i just have a question, do you have an internet connection when your computer connected to your modem(the device provided by your Internet Service Provider)? Possible that the Belkin not working is that maybe you don't have internet from ypur ISP.
I suggest you to connect your computer first to the modem, turn off the pc and afterwards the modem, after 2 minutes, turn on the modem first, when all lights stable, turn on the pc and check if you can go online. If not, better contact your ISP first for them to check the connection. If everything working fine with your ISP. Reply to this post again and provide the following information.
Your ISP?
Brand of the Modem?
Brand of the Belkin Router?
Type of Connection you have form ISP, DSL or CABLE?
If DSL, please make sure that you have a username and password from your ISP?
How many computers do you have?
What is the Windows Version your using or the Operating System?
Thanks.
Sep 29, 2008 | Belkin (F5D7231UK4) Wireless Router
No connection
Try resetting the router to factory , should have a button on the back to do this .
you will have to log back into it with the default factory password
see their site for more info.
Jan 26, 2008 | Dynex DX-E401 Router
Light on my RCA cable modem goes off when I connect a wireless router (Linksys WRT54G). It was workign fine for good 12 months until I was cleaning under the desk and zoom the light is out. When I connect...
It sounds like the ethernet port has actually gone bad on the router. The light turns on when the device detects a phyiscal connection to another device. Your modem does not detect a connection to the router... But it does the PC. So you know the issue is with the router.
Jan 01, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
806 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
