Question about HP Pavilion a1600n (882780776265) PC Desktop
I have a desktop that I am not getting any image on the monitor. I tested the monitor with a laptop and it is working just fine. I think it is the video card, but aren't they built into the board now, not seperate cards like they used to be? What is my next step? Thank you.
    Sergeant:
  • 235 Answers
If the video card is bad on the motherboard, you can install a pci video card on it.
Posted on Sep 05, 2010
Need both laptop and monitor on at same time.
Hey Roger,
Below is information that should help you with trying to get monitor and notebook screen to work.
First make sure your laptop is equipped to be able to connect a secondary display, there should be a port for connecting a standard monitor cable on the back.
Connect your secondary monitor and reboot the laptop, the system bios should recognize that a second monitor has been added.
Then right click on your desktop and bring up the display properties dialog box.
Select "settings"
Your laptop should be identified as monitor 1 and you should also be able to see the secondary monitor as monitor 2.
Click on the secondary monitor and check the box that says "Extend my Windows desktop onto this monitor".
Set your screen resolution and color quality for the second monitor and click apply.
Directing icons and browser windows over to the other monitor is just a matter of drag and drop.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 11, 2014 | Dell Latitude D600 Notebook
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
I have a dell Dimension 2300 and the images are very dark. I don't think it is from the monitor.
Try these steps: 1. Check the monitor settings. Access the On Screen Display (OSD) Menu System. Adjust the contrast and brightness using the control buttons in the monitor.
2. Run the monitor self test. Unplug the video cable from the computer (cable from monitor to the back of the computer). Usually it has a blue or white connector. Turn on the monitor alone. It should display the self test pattern (white, red, green & blue). If the images are dark in the self test, it is a problem with the monitor.
2. Rotate the monitor to face a different direction. This will help in eliminating sunlight glare which can cause poor picture quality.
3. Test your computer using another working monitor. If the problem occurs in a known good monitor, then it is a video card or motherboard (if your video card is integrated) problem.
I hope these options help.
Jan 19, 2010 | Dell Dimension 2300 PC Desktop
No image on onitor dell desktop -
if you have no image on the monitor when you hook monitor to other pc and you installed the video drivers for monitor and still no image then you got either a bad power cable for your monitor or your monitor is shot...get a new monitor... try testing again with a different power cable... if still the same... then monitor is shot... replace it...
Dec 22, 2009 | Dell Dimension 3100 PC Desktop
Dell monitor problem
Try pressing Fn + F8 keys to toggle the screen image.
Nov 30, 2008 | Dell E176FP 17" LCD Monitor
Sony Laptop Screen goes Grey
1.What I need you to test is...When laptop monitor go grey try plug external monitor and see that it work fine or not ??
2.Incase it work fine try to give a little tap behinde the laptop monitor and see that any changes...keep try and harder and see
3.Incase if you gave a hard tap also and its still the same but external monitor work fine then....I think you have problem with your LCD monitor coz there are chips that control the LCD crystal and maybe when it goes hot it behave this way....in this case you can't change the chip...you have to change the LCD.
takecare.
Jul 18, 2008 | Sony VAIO VGN-FS640W Notebook
I have a ViewSonic Monitor, model number Vs11307. The screen is all blurred and the screen isn't adjusting properly. The screen is shifted to the right and I have a blank rectangle at the left side. I...
I had the same problem same model. The image was off center to the right and it couldn't be fixed by the auto-image adjust or the manual adjust.
My solution was really simple, I moved a video player (RealPlayer) onto the monitor and maximized the screen, then pressed auto-adjust once. It worked.
Jul 14, 2008 | ViewSonic Computers & Internet
Monitor automatically clicks into power saving mode
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
Remote display/monitor
First try to reinstal the monitor display driver. Failing that working I would next borrow a monitor to see it it works. That wil tell you if it is a monitor or video card  problem.
May 22, 2008 | ASUS VW193T Monitor
HP Pavilion a1600n (882780776265) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
