My washing machine is approx 8 years old and when I put an extra large or large load in the machine leaks a substantial amount of water from the rear left side onto the floor. I'm wondering if the springs might need replacing or if it's something more cotsly?
  • jendixon23 Sep 05, 2010
    It is an LG 6.5kg Fuzzy Logic WF-T652A model.
  • 5,081 Answers
Potentially, two things could be happening.
Try putting less clothes in on the large load setting, once the tub fills with water, the level is too high and it will drain out the back.Open the washer door once it stops filling and check the water level. If it does this repeatedly the new washer needs the level adjusted.
If a garbage disposal is connected could be partially clogged when several drains operating at the same time, the drains can't handle the pressure.
I do think #1 is more likely.
Posted on Sep 05, 2010
Leaking water through pressure escape valve
Any coffee maker, espresso machine related sales-support issues you can always get in touch with www.De-Brewerz.com
Dec 16, 2013 | Pasquini Livia 90 Espresso Machine
Whirlpool Washer Model No. LXR-1564039, Serial No. CM-1564039, Type 107, Year 2006. Went using the extra large setting the washer leaks water from the bottom, however went filling for the rinse...
Although its difficult to say the problem may not be caused by the amount of water but the water temperature.
Most often rinse tempertaure is cold only, however the wash might be warm /hot. A great place to start would be when the machine is filling in wash watch the connectons from the taps to the machine for any leaks in the hoses or connections.
Hope it helps.
Nov 23, 2010 | Whirlpool Washing Machines
Whirlpool ultimate care extra large, about 10 years old. when the machine is in spin cycle, it throws the circuit breaker. It started with a heavy load, but now it seems to do it all the time. It started...
Water leaking from tub seal into motor possibly? Try doing spin with dry newspaper under the machine and check for leaks. Could also possibly be water heater element loose or breaking down - leaks from drain hose or water pump body into windings? Dry news paper test should highlight where leaks are coming from.
!0 years old is ancient for a machine and you might consider replacement rather than a repair which will only be throwing good money after bad. Do you drive a 10 year old car? if you do, you expect repair bills to mount up! same with washer. I bet it doesn't owe you much!
Jan 03, 2018 | Whirlpool LSW9700P Top Load Washer
My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
Jan 13, 2010 | GE Profile Performance WPSF4170WAA
Water leakage particularly when on full load. Machine is approx 9 years old. thanks
Could be main seal which is quite a large job, but advise looking inside could be a split drain hose to the pump, to access the inside, insert a flat blade 4" from each side between the front panel and the lid to release the clips. The lid will now hinge backwards, remove the 2 top screws on the inside of the front panel, this will now lift to remove. check the black hose at the rear of the drum to the pump.
Dec 13, 2009 | Admiral AW22 Top Load Washer
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hotpoint Top Load Washer LEAKING!! PVC pipe clogged? Help!
I have had the same problem with this washer so I tried putting it on Medium load and it works fine. Any time I try to put it on large load the leak happens every time.
Aug 24, 2008 | Hotpoint VBXR1090B Top Load Washer
Fisher and Paykel IW810AU fault code 105
I have found out from a repair agent that the fault code means there is no or corrupted communications between the display and motor drive module.
It may be simple as a loose cable, if the washing machine has been moved recently.
In my case I have a very slow little leak in the hot water solinoid (Bad spelling I know) thus causing it to leak on the circuit board and over time rust the connections. Basically my machine was not worth repair as the main circuit board was a tad too expensive. It was still cheaper than a new one (even after all the extra costs were put into consideration, ie - Labor and transport costs) but my machine is 8 years old and I thought for an extra couple of hundred dollars I could get a new one with warranty.
I know there are people out there bagging these machines, but 8 years out of a item (without any servicing) that uses moving parts, electricity and water is pretty good.
Hope this helps?
cheers
Dave
Apr 13, 2008 | Washing Machines
Whirlpool Topload washer dripping
of course its proably just a water valve leaking
Jan 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
